Old 10-08-2003, 10:46 PM   #1
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
Default dome light, map light, keyless entry will not work
I was doing some stereo wiring (splicing/crimping) in the dash and I think i might have shorted something. I know...I know I shoulda disconnected the battery but I was on my lunch break and bored so I didnt do it.
The dome light, the map lights, and the keyless entry now do not work. The power door locks will work if I use the buttons inside the car though. I do not have any alarm/security system.
I checked every single fuse in the car, even the ones that it wouldnt be associated with and all of them are good.
Any ideas??
Oh and the power mirror both sides are not working. The cigarrette outlet works which is on the same fuse. That stopped working a while ago!
Please help!
Samirr76 is offline   Reply With Quote
Old 10-08-2003, 11:08 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Gotta be a fuse somewhere. Did you check both fuse boxes? If you have a test light check the fuses that way rather then visually, it's possible for one to be blown and still look ok to the eye.
Old 10-08-2003, 11:39 PM   #3
SAW
Member#: 12061
2002 Black WRX
I had the same problem.
I would check the fuses again.
If it isn't a fuse, then there is a break somewhere in your splices (i don't know much about electricity). Once I found my bad slice, things worked fine for me.
SAW
SAW is offline   Reply With Quote
Old 10-09-2003, 12:51 AM   #4
cre
Member#: 18153
2008 M3
The fuse you are looking for is in the under hood fuse box. I think its labled clock. HTH
cre is offline   Reply With Quote
Old 10-09-2003, 08:41 AM   #5
Samirr76
Member#: 4835
2003 Baja 5MT
It turns out I didnt see the "clock" fuse under the hood because it was dark out last night and I was in a hurry. I found it this morning in daylight, lo and behold, it had blown the 15amp fuse. I replaced it and everything works again!
Except for the power mirrors. I will pull up the console to see if the harness came loose.
08 Dome light out and keyless entry Subarudave09 Electrical & Lighting 7 Yesterday 01:28 PM
2003 WRX Keyless Entry Intermittently Not Working Cody Car Audio, Video & Security 31 04-28-2014 10:43 AM
Keyless entry horn not working?? GTR STI Car Audio, Video & Security 13 08-30-2007 07:32 PM
Keyless entry does not work when WRX is running?? burton13 Car Audio, Video & Security 9 10-28-2002 11:51 AM
