Old 10-10-2003, 10:07 AM   #1
bullseye17
Member#: 16661
1997 Outback
Green
Default Rallispec RA Gearset / Exedy Flywheel
Gearset alone, installed at Northtown Subaru into stock box.
OMG, this is the gearset subaru should have installed to begin with.... every gearratio is absolutely perfect, no longer is that annoying 1-2 shift there. It feels like im driving a totally different beast, and is the single best upgrade (other than tires) i have done on my car since the day I bought it. The gearbox also feels alot tighter, but goes into every gear perfect, even first on a roll.
Im using Mobil 1 75w-90 Gear oil, as Rallispec Recommended.
The only big downfall is that at 75mph in 5th gear, its running about 3550 (approx) RPM.... def not a highway mileage car anymore. (as if it ever was). The 4-5 Shift happens around 100mph. I think the best way to describe it is a 6 speed transmission without 6th gear.
The flywheel feels great, no chatter in the morning yet, revs drop and rise quickly and smoothly, the only thing hard getting used to, is giving it a bit more throttle to get it moving. Ive stalled it a number of times already. It also gets worse as it gets warmed up.
bullseye17 is offline   Reply With Quote
Old 10-11-2003, 05:27 PM   #2
neverendingmods
Member Sales Rating: (1)
Member#: 23796
2006 STi
white
What clutch kit are you using? Also, how is gear noise and decel noise now compared to stock tranny/flywheel?
Thanks
neverendingmods is offline   Reply With Quote
Old 10-13-2003, 10:17 AM   #3
wRx14pSi
Member#: 6203
Default Re: Rallispec RA Gearset / Exedy Flywheel
i am confused?? so the max that 4th holds is ruffly under 100 ??
is it possible to change 5 gear to get some top speed??
wRx14pSi is offline   Reply With Quote
Old 11-28-2003, 09:54 PM   #4
exhacker
Member#: 33725
2008 Impreza WRX 5dr
What was your total cost and downtime for the gearset?
EDIT: Can you please list your speeds at 4000rpm and 6000rpm in each gear, along with your tire size (if not 205/55/16)????? Don't kill yourself on that last gear. I'm mostly curious about 1st through 4th.
Thanks for the review. Keep the updates flowin`
-x
exhacker is offline   Reply With Quote
Old 12-02-2003, 02:11 AM   #5
exhacker
Member#: 33725
BUMP.
I did my own research. My tires are bald Falken Azenis running low (34psi) pressure, 205/55/16 on stock wheels.
Mods are canister exhaust, stock gearbox with no mods.
I don't think the exhaust would affect these numbers:
2003 WRX Speeds
1st Gear
4000rpm = 21mph
6000rpm = 31mph
2nd Gear
4000rpm = 37mph
6000rpm = 51mph
3rd Gear
4000rpm = 52mph
6000rpm = 79mph
4th Gear
4000rpm = 75mph
Sorry, I can't safely go any faster until I get out of town. Can anyone test out these numbers on stock tires at stock pressure to verify??
bullseye17 - get back to us with those #'s !! :-)
ty,
-x
Old 12-04-2003, 12:24 AM   #6
Big Turkey
Member#: 32118
How much did the RA gearset costs? And where did you purchase it?
Big Turkey is offline   Reply With Quote
Old 12-04-2003, 02:33 AM   #7
CirrusWRX
Member Sales Rating: (4)
Member#: 17439
2002 x2 Silver WRX
Sedan, White WRX Wagon
I'm guessing it came from Rallispec?
CirrusWRX is offline   Reply With Quote
Old 12-17-2003, 10:44 AM   #8
WRXeFEX
Member#: 8215
2002 Impreza WRX
WR Blue
I brought my car to the track and I am going through the traps at 110 at the very end of fourth gear. I think I paid like 1500 about a year ago for mine. Gruppe-S has them pretty cheap now.
Mike
WRXeFEX is offline   Reply With Quote
Old 12-18-2003, 04:10 PM   #9
exhacker
Member#: 33725
so what are your times in the mile, since you've already taken a few runs? Thanks!
Old 12-21-2003, 11:16 PM   #10
Siper2
Member Sales Rating: (33)
Member#: 1134
2010 Legacy GT Ltd.
Impreza GC8
Okay. I know the gearing between the GC 2.5RS and the new WRX are obviously different, but...
...a ~3500 rpm at 75mph sounds pretty normal, to me. My car runs about the same with a stock transmission.
I don't know if the RA set in my car would be that drastically different or not, but right now it seems I wouldn't lose out on highway gas mileage at all, really.
Hell my '94 Acura Integra RS ran at about 4300+ rpm at 73mph.
The Impreza may as well be a Lexus.
-S2-
Siper2 is offline   Reply With Quote
Old 02-21-2004, 12:01 PM   #11
EJ25STi
Member Sales Rating: (14)
Member#: 35881
can you still get to 60 in second with the new gear set?
EJ25STi is offline   Reply With Quote
Old 02-28-2004, 05:19 PM   #12
sonicowrx03
Member#: 41566
I am running the stock gear box on my car but I am curious to know if the RA set will hold up the power of my mods.
18 G fp turbo
PE 650cc injectors
Walbro fuel pum
Borla headers
sti scoop
tmic from Turbo Xs
Gredy cat back
hks Down pipe
tmic gt Spec spliter
CAI intake
Utec computer
Lineage grounding kit
I need your opinions, I am looking for a good reliable and strong gearbox fix for a daily driver WRX. Thanks
sonicowrx03 is offline   Reply With Quote
Old 03-07-2004, 09:50 AM   #13
el~sharko
Member Sales Rating: (5)
Member#: 29735
2011 JSW TDI - DSG
2008 EVO X MR
should be able to go further than the us box. the big differences i believe are shorter 3 and 4th gears
el~sharko is offline   Reply With Quote
Old 03-08-2004, 08:34 AM   #14
jsmonet
Member#: 14190
2005 STi
white
and taller first. our oem first gear is absurdly (and uneccessarily) short.
jsmonet is offline   Reply With Quote
Old 06-01-2005, 08:52 PM   #15
nightrider2004
Member#: 71829
2002 Subaru WRX
black with pearl blue
A big thank you as well goes out to rallispec for awesome customer service... And thank you to the other companies who reffered me to rallispec due to my desperate situation... Thanks again rallispec/others for helping me out with my situation!!!
-Jon
nightrider2004 is offline   Reply With Quote
Old 06-02-2005, 06:18 AM   #16
Paul
Member Sales Rating: (41)
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
[quote=wRx14pSi]i am confused?? so the max that 4th holds is ruffly under 100 ??
Old 06-02-2005, 02:43 PM   #17
nightrider2004
Member#: 71829
2002 Subaru WRX
NOTE: rallispec called me to tell me themselves not to use Mobil 1 gear oil, unless its the shc or whatever it is...
again thanks to rallispec for everything!
-Jon
Old 07-24-2005, 01:25 PM   #18
roninsoldier83
Member Sales Rating: (16)
Member#: 61966
2016 Golf R & 13 WRX
Sold: 06 STI & 15 WRX
I'm not positive, but the starter of this thread's profile says he drives a '97 Outback, and again I could be wrong, but I think most older Subaru 5 speeds come with a 4.10 final drive, as opposed to our 3.9, so that is probably why he has to shift to 5th around 100mph, ours should be a little higher than that.
roninsoldier83 is offline   Reply With Quote
ONE JDM V6 SE Gearset!! STI 6-spd gearset Exedy Clutch Combo's with the Flywheel $599 Gruppe-S Drivetrain 5 09-15-2006 06:01 PM
STi V6 RA Gearsets, Cusco Motor Mounts, ACT and Exedy Clutches and Flywheels Z1 Performance Drivetrain 13 10-10-2005 06:15 PM
Brand new Ra gearset, Exedy Clutch and Flywheel TXSnEj20 Private 'For Sale' Classifieds 5 05-23-2005 08:02 PM
'99 OBS converted by RalliSpec - Pics of RA gearset/Car included Geoff Subaru Conversions 5 04-04-2004 05:24 AM
Rallispec STi Ra Gearset and Quaife Front Differential Review Silver Bullet 02 Transmission (AT/MT) & Driveline 2 10-13-2003 04:35 PM
