Old 10-10-2003, 12:40 PM   #1
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
Default Now I went and did it...I've got an HDTV
So yeah, who can give me tips on properly tuning the colors and such?
Got it last night because I thougth my current TV was b0rken. Hooked up the HD, and of course, the problem was with the cable. Either wya, I'm going to hang on to the HD now.
I know that the out-of-box color visual settings aren't the best. With nothing special to help me, like a DVD, what's a good way to get a nice color balance on this thing?
(hometheaterforum.com is blocked from work for some reason)
JGard is offline   Reply With Quote
Old 10-10-2003, 12:42 PM   #2
m750
Member#: 2278
8Sti | 07 allez
White | Comp
m750 is offline   Reply With Quote
Old 10-10-2003, 12:42 PM   #3
gongzero
Member#: 25040
Up with skirts,
down with pants!
what's the make/model?
try avsforum.com - their Display Devices forum should hold plenty of useful info.
gongzero is offline   Reply With Quote
Old 10-10-2003, 12:47 PM   #4
CandyO
Member#: 36091
2006 Golf TDI
FTW!!!
IBSC-WReXSaysheWantsOneToo
CandyO is offline   Reply With Quote
Old 10-10-2003, 12:49 PM   #5
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
oh, it's the Advent 27", 1080i. Not sure on the exact model number.
Basically, I was at the store last night, kinda in a panic, thinking I needed a TV.
It came down to this one for $469, or an open box of the same brand at 32" for $599.
I figured there'd be no way in hell I could lift the larger one, or fit it in my car, so I got the smaller one (which also barely fit in my car, and I needed help lifting)
Old 10-10-2003, 12:54 PM   #6
gongzero
Member#: 25040
Up with skirts,
down with pants!
angelo is saving up for one of these:
Samsung HLM507W 50" DLP HDTV
let's see... only C$4500 to go!
Old 10-10-2003, 01:01 PM   #7
gongzero
Member#: 25040
Up with skirts,
down with pants!
hmm, i'll see what i can find.
Old 10-10-2003, 01:46 PM   #8
TimStevens
Member#: 4817
2012 STI, '02 WRX
'91 MR2, '05 Speed Triple
Any idea if it supports 720p natively, JGard? Seems like a great price for an HDTV, and that's about the size I'd be looking for...
:edit: Unfortunately not
http://www.ce.org/publications/books...isting2003.pdf
TimStevens is offline   Reply With Quote
Old 10-10-2003, 02:00 PM   #9
live311
Member#: 10801
2008 Outback
Do you get lots of HD programming in Beantown? Around here we only get 5 channels from digital cable and only 2 are network (neither of which carry football or baseball)
live311 is offline   Reply With Quote
Old 10-10-2003, 02:09 PM   #10
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
I'm not sure I know what you mean.
I know it does 1080i, and it does 480p, so I would think it could do 720p, no? I'll have to look at the manual when I get home. Best buy's site is worthless, and I can't find Advent's web site.
Old 10-10-2003, 02:11 PM   #11
TimStevens
Member#: 4817
2012 STI, '02 WRX
Lots of TV's convert a 720p signal up to 1080i. Since the TV channels around here broadcast in 720p and a few Xbox games are 720p, I'm trying to find a reasonable HDTV that supports it natively.
Old 10-10-2003, 02:12 PM   #12
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
don't know yet! I'll find out soon, though
Old 10-10-2003, 02:13 PM   #13
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
ahh... actually, most channels are 1080i, only ABC and affiliates are 720p.
My TV wasn't even listed on that PDF...so let me see what I can find online.
Old 10-10-2003, 02:16 PM   #14
TimStevens
Member#: 4817
2012 STI, '02 WRX
Oh, sorry. The 32'' model is. I figured yours would be the same.
Old 10-10-2003, 02:20 PM   #15
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
well, I can't find anything on there...but I'm guessing you're right.
From what I've read, you can't really see any difference between 720p and 1080i
Old 10-10-2003, 02:21 PM   #16
rkkwan
Member#: 5596
2010 Honda Fit Sport
JGard - Get a test DVD to help you adjust the TV's setting. Best two right now are:
Sound & Vision Tuneup - from the S&V magazine. Easy and simple to use for beginners.
Digital Video Essential - much more advanced, with lots of test patterns you can use, if you want to go into the service menu of the TV to do adjustment.
Both are about $18 online.
About 720p and 1080i. Most CRT-based HD monitors are 1080i native, while LCD/LCoS/DLP and plasmas are usually 720p. Both are HD, and really doesn't matter usually, as all set-top-box will output both.
Only problem is with 720p XBOX games. If your TV won't accept 720p (like many CRT models), than you can't play those games in HD.
rkkwan is offline   Reply With Quote
Old 10-10-2003, 02:22 PM   #17
Jasvboost
Member#: 37160
RIP 04 Stg2 JBP WRX
07 SWP WRX 335/350 HTA68!
Thumbs up
http://www.hdtvoice.com/voice/index.php
This forum has lots of info for you to read about. Use it well.
Jasvboost is offline   Reply With Quote
Old 10-10-2003, 03:04 PM   #18
philip_g
Member#: 32906
*sigh*
no one has mentioned www.hometheaterforum.com ??
philip_g is offline   Reply With Quote
Old 10-10-2003, 03:12 PM   #19
beethoven
Member#: 6654
2006 Odyssey
2006 Prius
Originally posted by philip_g
*sigh*
*sigh*
Some people just can't read these days.
BTW, JGard, expect to be underwhelmed by HDTV. You'll find that most HDTV is broadcast in 16:9 which will be letterbox on a 4:3 TV if your TV or receiver support that (it should). What's great is when a 16:9 broadcast shows a 4:3 recording...then your TV just looks small.
But, not all channels use 16:9 format. Our local CBS station does not. So you have to switch setting back and forth depending on the channel you're watching.
Also, most programming isn't even in HD, so even though the signal is, it only looks marginally better.
That said, HD programming with an HD tuner and TV look great.
beethoven is offline   Reply With Quote
Old 10-10-2003, 11:21 PM   #20
Bwana
Member#: 39084
05 LGT Ltd 5mt
Speaking of HDTV...tonight i saw an Alero w/ the license plate: LUV HDTV
Thought of this thread immediately.
Bwana is offline   Reply With Quote
Old 10-10-2003, 11:51 PM   #21
Charge
Member#: 3313
My friend has that 50" Samsung DLP. It's beautiful.
He has about 10 HDTV channels via his digi cable. There are 6 stations locally in my area(Cincinnati) that are broadcasting over the air in digital. You do need a specific antenna to capture that kind of broadcast...and obviously a HD tuner. Our local cable provider gives you a tuner with their "HD" service(which is free with digital cable....they just have to send a tech out to see that you have an HD TV to give you the box). You pay the same rental fee for that box as for a regular digital cable box. It's just able to feed the signal to the TV in digital format on the HD channels.
For switching between the modes(16:9 and 4:3), he just programmed a function into his remote to bounce between the two. If he flips to a channel in 16:9, just hit the button and it swaps to the other mode.
Neil
Charge is offline   Reply With Quote
Old 10-11-2003, 02:05 PM   #22
obyone
Member#: 16523
Ummm....most X-box games I've seen, that run HD, only run it at 480p. I've yet to come across a 720p, or 1080i.
obyone is offline   Reply With Quote
Old 10-11-2003, 02:15 PM   #23
Keenan
Member#: 2277
2001 Impreza 2.5RS
Sedona Red Pearl
720P:
EPSN NFL Football
Soul Calibur II
Unspecified on case:
Unreal Tournament
Three of my eight games support high definition.
The others that don't are older.
Keenan
Keenan is offline   Reply With Quote
Old 10-11-2003, 02:37 PM   #24
obyone
Member#: 16523
Soul Calibur is 720p? I was playing the demo and thought it was 480p....oh well.
Old 10-11-2003, 11:14 PM   #25
TimStevens
Member#: 4817
2012 STI, '02 WRX
Yep, Soul Calibur is the 720p gaming poster child.
Well I went and did it and listened to some of you jslegacy Mid Atlantic Impreza Club -- MAIC 20 07-04-2003 03:41 AM
oh no..I went and did it b_tapper Off-Topic 43 04-30-2003 10:26 PM
Now I went and did it....HELP! gusman21 Tri-State Area Forum 12 08-17-2002 12:24 AM
Finally went and did it.... Judge Newbies & FAQs 5 02-15-2002 02:55 PM
Attn Kris and Mark Uh Oh i went and did it scoobyruman New England Impreza Club Forum -- NESIC 9 08-16-2000 08:30 PM
