Old 10-10-2003, 12:36 PM   #1
zimm
Member#: 44427
Default How to take apart factory boost gauge
I want to take my factory column mounted '04 STI boost gauge apart to put a red light bulb condom in it. Anyone know how to do this?
I tried searching, but it just times out...
zimm is offline   Reply With Quote
Old 10-10-2003, 12:59 PM   #2
Orson
Member#: 25254
2003 WRX wagon
The cup is rubber, so you can bend the lip back, one bit at a time, and get your finger or a screw-driver in there to pry it out. Some lube may help, but I have never needed it. After you pry it out slowly, the bulb is just a twist-off part.
Orson is offline   Reply With Quote
Old 10-10-2003, 05:24 PM   #3
JCampbell
Member#: 25159
2015 BrAkes stop you
BrEAks make you broken
I used a few wooden tongue depressors. The rubber cup has a pretty good grip on the gauge.
JCampbell is offline   Reply With Quote
Old 10-12-2003, 01:56 AM   #4
thechoochman28
Member#: 42900
I just put my lil Subaru issue screwdriver in between the rubber and the gauge (be careful not to scratch the part of the ring that u see) where their's a lip from the gauges face and pryed it out till i could get a hold of it...then *pop* comes right off...it helps to put the steering wheel down too when u do get it off so the boost hose isn't to tight...then inside their is a lil connector that u can pull off and also the light is in that black nub that u just turn and then pull out. You'll notice their is already a condom on it but it does diddle sqaut.
thechoochman28 is offline   Reply With Quote
Old 10-13-2003, 12:13 PM   #5
LYHTSPD
Member#: 26374
2004 WRX Sedan
San Remo Red
are there any direct replacement colored bulbs that fit? I am thinking about doing this for my 04 sedan. What size bulb is it?
LYHTSPD is offline   Reply With Quote
Old 10-13-2003, 04:03 PM   #6
Orson
Member#: 25254
2003 WRX wagon
There are no colored bulbs. But there are bulb covers, also called bulb condoms. The stock bulb has a blue condom on it (to make the light slightly white). I ordered up some green bulb condoms from www.partsexpress.com (the 0.2" ones). The color isn't exact, but it is better than stock.
I offered them for sale a little while ago as a favor to the community since I had plenty left ($1 each via Paypal), but only three people bit. If you want a green one, you can PM me.
Old 10-15-2003, 02:27 AM   #7
NewShockerGuy
Member#: 40736
2005 WRX STI
Arrow
I just tried to remove the stock boost gauge... I can't get it out at all. When I stick a screw driver in the housing I start to "bend" the damn part that is mounted on the steering colum... I DON'T want to break anything... I just want to change the condom to red because I did that with everything else in my car... Why is this so hard?
lol.... :-(
-Nigel
NewShockerGuy is offline   Reply With Quote
Old 10-16-2003, 04:40 AM   #8
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
Hey Orson,
I couldn't find where the bulb condoms were on that site, could you direct me please?
And you said the factory has a blue bulb condom? So then does that mean I can't make the guage light up blue?
Thanks
verc is offline   Reply With Quote
anyone know how to take apart a turbo?? red_soul_D Vancouver Impreza Club Forum -- VIC 16 10-27-2004 11:05 AM
How accurate is the factory boost gauge compared to other gauges? snvin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 39 08-06-2004 10:44 PM
how to take apart seatbelt? BOFslime Interior & Exterior Modification 6 06-16-2004 03:00 AM
How to take apart an HKS SSQV Tut4u2 Newbies & FAQs 1 01-22-2004 09:11 PM
How to take apart... Keiho Car Audio, Video & Security 4 12-05-2000 06:53 AM
