Old 10-10-2003, 02:56 PM   #1
Dolphin Overton
Member#: 1925
01 A4 89 944s2
13 Speed 3R 99 Sprint
Default Battery relocation Q.
I am about to relocate my battery to the trunk and was wondering if there would be any issues using the stock battery back there. Someone told me you need a stronger battery when going from the trunk... this doesn't seem right. Anyone got any info? suggestions? good prices on boxes etc.?
Dolphin Overton is offline   Reply With Quote
Old 10-10-2003, 06:20 PM   #2
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Not sure why you would want to, since you'll need to run something like 0 gauge power wire to the front, which isn't light, and physically protect it from any chafing etc so you don't get a car-B-Q.
Old 10-10-2003, 08:23 PM   #3
LinuxGuy
Member#: 17270
1998 Fender Bender
Holds 1000lbs.
Just curious, did you buy a kit or are you making up a homemade system?
Stock battery should be ok in the trunk.
LinuxGuy is offline   Reply With Quote
Old 10-11-2003, 02:03 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I put an Odyssey PC680 under the passengers seat a while ago, and it works great. I used 4ga. power cable to run the pos. to the front and used the seat bolt for the neg. and have had no problems. i also used an Anderson connector(SB120) to make it easy to install/remove.
The car changes directions better with the weight off the front end, and generally feels lighter up front.
I'll see if I can get a link to pics going....
Old 10-15-2003, 03:44 AM   #5
Dolphin Overton
Member#: 1925
01 A4 89 944s2
weight distribution. it's nothing new, it's a basic principle. take 30 pounds from in front of the front axles, and put it behind the rear axles. so it's not for overall weight reduction, it's for distribution... not for drag racing.
I am getting a Moroso kit(really nice kit with breather and high quality box) and using my own cable... either 0 or 4 gauge. dunno what yet.
Old 10-16-2003, 01:20 AM   #6
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
4 gauge may be a bit small -- check out:
wire gauge current capacity for standard run (roughly length of car)
The Moroso box *does* look nice; where do you run the vent hose?
Old 10-16-2003, 10:16 PM   #7
tdxflex
Member#: 13634
Specs I got from knukonceptz,
0ga wire weighs 0.40 lbs/ft
2ga wire weighs 0.25 lbs/ft
For extra protection I ran split loom where the wire needs to pass by tight clearances like the rear seat and firewall areas. I'm using 0ga wire, a lot of battery relocation kits use 2ga, the only person I know that has a battery in the trunk that uses 4ga is NavyBlueSubaru and it's been working out ok for him.
tdxflex is offline   Reply With Quote
Old 10-17-2003, 04:11 AM   #8
Dolphin Overton
Member#: 1925
01 A4 89 944s2
thanks tdxflex
armand1: the vent hose goes out th ebottom of the car so you have to do some drilling. it's a bit scary, but there is a graumet and everything so it should be OK.
i think i am going to get the entire Moroso Kit. wires, box, terminal etc. My friend can get them at cost, so it will be significant;y cheaper than online
Old 10-19-2003, 02:50 PM   #9
koolaid
Member#: 43491
1997 Impreza Outback
Red
you could also get a dry cell battery so as to not worry about the troubles of fumes or tipping over
koolaid is offline   Reply With Quote
Old 10-19-2003, 10:03 PM   #10
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
what about the ground cable that is still in the motor bay compartment?
i have some things that are grounded off of that, so do you just ground it to the chassis?
subiekid is offline   Reply With Quote
Old 10-19-2003, 11:15 PM   #11
koolaid
Member#: 43491
Red
yes.. usually to the strut tower, or make a new hole
Old 10-20-2003, 12:09 AM   #12
Dolphin Overton
Member#: 1925
01 A4 89 944s2
a dry cell battery is OK, but tranfering the stock battery to the rear of the car is more effective for balancing the car. the moroso kit will not allow tipping or any fumes to get into the car. dunno if i have the cash right now though, i need new rear brake pads now
Old 10-20-2003, 02:09 AM   #13
atomicapples
Member#: 12626
02 2.5 rs
doesnt the stock battery a wet battery and will release some toxic fuses?
i relocated my battery, but i used a drycell...
atomicapples is offline   Reply With Quote
Old 10-20-2003, 05:39 AM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
I moved the battery(a 'drycell'..no fumes, can't leak even if split open) under the passengers seat, after careful consideration.
This position is better than the trunk for several reasons, balance being one.
Under the seat is lower and closer to the center of the vehicle(offsets some of the drivers weight) than the trunk, and the battery I used is about half the weight than the stock battery WITH all associated hardware used for the installation. The Moroso kit adds weight to the stock battery and the cable to run to the front must be of heavier guage and more must be used.
No trunk space is used if the battery is located elsewhere.
My install may not be legal for some race sanctioning bodies, but I'll deal with that if and when it becomes necessary.
Old 10-21-2003, 12:24 AM   #15
subiekid
Member#: 25516
hey uncle scotty? what type of battery are you using? doyou have a pic? is it the one that is like half the size of the oem battery? where did you get it?
Old 10-21-2003, 01:47 AM   #16
Uncle Scotty
Member#: 16200
OK buy Nates beans
I'll bet you didn't read this thread, did you?
Old 10-21-2003, 02:11 AM   #17
subiekid
Member#: 25516
i been ow3ned.
i just ordered a summit trunk mount kit. 34 bucks, its got a box and 20 feet of 2 gauge wire, and 3 feet for the ground.
how do i ground the ground cable in the motor bay? does anyone make like battery posts that you can bolt do the chassis?
Old 10-24-2003, 10:12 PM   #18
subiekid
Member#: 25516
the summit kit is very nice. the box is kinda cheap, but it will be ok.
i will get install pics some time next weekend.
Old 10-25-2003, 01:23 AM   #19
atomicapples
Member#: 12626
02 2.5 rs
i been ow3ned.
you can ground it to anywhere in the truck.
i grounded the battery in the trunk to the frame rails.
Old 10-25-2003, 01:24 AM   #20
atomicapples
Member#: 12626
02 2.5 rs
let me try to get some pics up...
Old 10-25-2003, 05:55 AM   #21
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
For those of you doing battery relocations without running a ground cable back up front along with the +12V cable, remember that the steel in the body conducts electricity less well than does a copper cable. Thus, if you hook up your battery (-) to the body in the back near the relocated battery, up front the difference between your +12V cable and the engine compartment ground is going to be less. Similarly, the actual charging voltage from the alternator that the battery sees at its terminals will be less than normal. Just something to keep in the back of your mind if you get some weird electrical problems.
Old 10-25-2003, 12:24 PM   #22
tdxflex
Member#: 13634
There is a lot of steel though, I would be more concerned about the contact from the battery to the frame. Strip all of the paint off, spray a little dielectric grease, and make sure the ring terminal is sandwiched well to get maximum surface area contact. I just grounded to one of the rear seatbelt bolts, have had no problems at all in the last 3-4 months.
Old 10-25-2003, 04:49 PM   #23
Uncle Scotty
Member#: 16200
OK buy Nates beans
This is why I ran a secondary 8ga. ground to the gounding point on the on the drivers side of the intake manifold.
Old 10-25-2003, 10:14 PM   #24
subiekid
Member#: 25516
did you just cut the end off of the ground wire and put on an end that would alow you to bolt it do the chasis?
Old 10-26-2003, 06:18 AM   #25
atomicapples
Member#: 12626
02 2.5 rs
thats alot of wiring.
what i did was i dremeled some paint off in the back, and grouded it, and then got some car paint (aspen white) and just resprayed it. no problems, been using it for the past 11 months.
Battery relocation, with conventional Battery. azn0boi04 Electrical & Lighting 3 02-23-2010 11:06 PM
Battery Relocation Kits BongMan Normally Aspirated Powertrain 25 09-16-2001 01:29 AM
('93-'01) Battery relocation questions Imprezer Impreza Forum 2 06-05-2001 04:50 AM
For sale: battery relocation kit bill harvey New England Impreza Club Forum -- NESIC 3 03-04-2001 03:39 PM
Battery Relocation? Jeff 2.5RS Newbies & FAQs 2 10-16-2000 09:58 AM
