#1 |
Member#: 11864
Vehicle:2002 WRX Silver |
my passenger side head light just went out.. At first I thought it was just a burnt buld.. got a replacement bulb. but the new one still wont come up.. i check the fuse under the hood to make sure its not a blown fuse, but didnt see anything wrong with it.. where else can i check???
#2 |
Member#: 10299
Vehicle:2002 WRX Sedona Red Pearl |
Are you using headlights other than stock that require a harness? I have a similar problem with my EDM lights and harness, looks like the harness has shorted. Try moving the wires around and see if you can get the headlight to come back on....
#3 |
Member#: 11864
I have the stock headlight assembly on.. it just went out 2 nights ago..I try move the wires around. no good. anyone else have this problem with stock lights..
#4 |
Member#: 11864
problem fixed.. the connector's metal plate was pushed in a bit somehow. so no continuity for the low beam.. pull the plate out a bit and problem solved.. now how do you close a thread????
| Thread Tools | |
| Display Modes | |
| LIghts out need help | noburo408 | Electrical & Lighting | 9 | 08-13-2009 01:46 AM |
| My 1st and 2nd gear went out! Need help went taking out tranny? | Kavaoski_08 | Transmission (AT/MT) & Driveline | 4 | 09-29-2007 10:16 PM |
| Need help! Big part out need help goin back to stock. Ill supply the beer! | Rick Dizzle | Mid West Subaru Owners Club Forum -- MWSOC | 12 | 07-04-2007 07:56 PM |
| Gauge Light Out, Need Help On Replacement | scubette97 | Electrical & Lighting | 3 | 03-27-2005 12:49 PM |
| "RB5" Brake Light Bulb. Need Help! | AliasAngel | Interior & Exterior Modification | 15 | 08-25-2001 02:17 PM |
