Old 10-05-2003, 03:45 PM   #1
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
Default Clear Headlights for 2000 Legacy Ltd?
I got an 2000 Legacy GT Ltd.
Would the clear headlights mod be the same for my car as the WRX, just a little different (shape of light)
Could someone list all the steps needed to do this mod. Thanks! also, has anyone done it successfully on a 2000+ Legacy? Im thinking about doing it sooon..
Acejam2k is offline   Reply With Quote
Old 10-05-2003, 06:13 PM   #2
subefriek
Member#: 11214
2001 legacy Gt
titanium
Default Headlamps
You mean like this?
Pat
subefriek is offline   Reply With Quote
Old 10-05-2003, 08:10 PM   #3
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
Yes, exactly like that. How do i do that?
Old 10-05-2003, 11:40 PM   #4
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
any1?
Old 10-05-2003, 11:57 PM   #5
biggreen96
Member#: 12535
vf39 06 5MT XT
92 Legacy Rally EG33'd
preheat oven to 200 or so. cook them for about 5mins and pull the halves apart when the glue melts, and pop out the yellow reflector. thats the short version. hit up scoobymods.com for the detailed instructions.
I know its nerve racking to cook important pieces of you car but its the way its done.
biggreen96 is offline   Reply With Quote
Old 10-06-2003, 07:55 PM   #6
subefriek
Member#: 11214
2001 legacy Gt
titanium
Default Headlamps
Acejam like biggreen says you can do a search in scoobymods for how to take the headlamps apart, you can do it this way but any that I
have seen done this way the plastic looks all melted to hell.
You have to heat them in an oven for about twenty minutes not 5 minutes like Biggreen says and then bend all the tabs back before forcing the lamp apart, I did it without heating or splitting the lamp.
Basically what I did was after taking the lamp off the car and working through the flasher or parking lamp hole using a fairly small flat blade screwdriver I forced the yellow reflector out of its groove, then I heated an old screwdriver with a propane torch, again working through the two holes I held the reflector with needle nose pliars and carefully sliced it up a bit at a time with the hot screwdriver.
It was time consuming and you need a steady hand so as not to let the hot screwdriver hit the chrome reflector or the lense of the headlamp as both are plastic, but if you do it this way you have no worries about moisture inside the headlamp no melted plastic and you will never know it was touched.
Pat
Old 10-06-2003, 08:44 PM   #7
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
Default Re: Headlamps
that sounds like a much better way. I will try and do it tomorrow night if I have time.
Old 10-11-2003, 05:08 PM   #8
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
Ok I went and did the mod...
I cooked them for about 15 mins each, took em apart, popedout Amber reflector, heated them back up, then re-sealed them using a combination of stock glue stuff, and some windshield/headlight sealant.
The stock turn signal bulbs are amber/oragne. If I put clear ones in, would that make it illegal?
Old 10-11-2003, 11:17 PM   #9
biggreen96
Member#: 12535
vf39 06 5MT XT
use clear bulbs that flash orange. or lightly dust the stockers with silver paint. Not using amber turn signals is asking to get hit IMO.
Old 10-12-2003, 02:49 AM   #10
nitrohuffer
Member#: 6982
2001 Legover
04 forester xt
I'm just too sketched out about doing it. But it looks so nice!
nitrohuffer is offline   Reply With Quote
aftermarket headlights for 2000-2004 legacy gt subarumafia700 Electrical & Lighting 2 03-28-2010 02:16 PM
WTT : 1 05 non cleared headlight for a cleared headlight kcook MAIC Private Classifieds 11 06-23-2007 04:06 PM
WTT 04 clear headlights for black housing headlights elmer20 MAIC Private Classifieds 1 07-12-2006 07:26 AM
Looking for clear headlights for a 04 WRX Blue_dragon Private 'Wanted' Classifieds 1 01-14-2005 03:12 PM
Clear Headlights for older impreza's ? awd_dreamin Interior & Exterior Modification 1 05-19-2004 02:23 AM
