Old 10-12-2003, 02:27 AM   #1
apemanwrx
Member#: 25082
Kubasaki High 4life
Default JDM headlight adjustment???
can someone please explain to me how
to adjust the vertical pitch on my jdm's.
i've noticed that on the back of the headlamp,
there seems to be two different adjustment
knobs..both can be fitted with a 8mm or 5/16
socket.
are these the correct adjustment points???
which one adjusts the beam on the projector lamp?
or am i just way off on this, any insight would be
greatly appreciated. these are the non-hid version.
thanks again.
kiyoshi
apemanwrx is offline   Reply With Quote
Old 10-12-2003, 02:30 AM   #2
pityr
Member#: 31719
the lower one adjust the vertcal and the "slightly higher off to the side" one is the horizontal.
These adjust the whole assembly on the inside including the projector and high beam.
pityr is offline   Reply With Quote
Old 10-12-2003, 01:42 PM   #3
apemanwrx
Member#: 25082
Kubasaki High 4life
pityr,
thank you for the clarification.
stripped jdm headlight adjustment screw! ASpec818 Electrical & Lighting 9 05-04-2007 12:36 PM
JDM Headlight Adjustment ? 4npower Electrical & Lighting 0 09-03-2006 01:49 AM
JDM Headlight Adjustment Uncle Ben Electrical & Lighting 3 05-06-2005 05:27 AM
JDM Headlight adjustments? wolfman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-24-2003 12:51 AM
JDM Non-HID Headlight adjustement zacek Interior & Exterior Modification 1 06-04-2002 10:38 PM
