Old 10-12-2003, 02:31 AM   #1
cre
Member#: 18153
2008 M3
Default Can the clock wiring support 2 gauges
Can the clock wiring support 2 gauges and the factory clock. I tapped my clock for my boost gauge and its fine. I am about to install my EGT and I am hoping the wiring can support it.
cre is offline   Reply With Quote
Old 10-12-2003, 03:58 AM   #2
atomicapples
Member#: 12626
02 2.5 rs
im pretty sure it can. iv seen people put up to 3 guages there.
but i would double check on that.
atomicapples is offline   Reply With Quote
Old 10-12-2003, 01:32 PM   #3
LinuxGuy
Member#: 17270
1998 Fender Bender
Holds 1000lbs.
The Triple gauge cluster that subaru offers for the impreza uses the clock wiring, I dont see why not.
LinuxGuy is offline   Reply With Quote
Old 10-12-2003, 01:37 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
There are two separate circuits in question, one for illumination which is the same circuit as all the other dimmable dash lights, and the other for accessory power to run the gauges that are electrical. The bulbs used in the gauges are small and don't pull much additional current from the illumination circuit, and the electrical gauges don't draw that much current either, so running a few gauges together is no problem.
Old 10-12-2003, 03:09 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I have my lights for my Autometer SportComp EGT and boost guages tapped to the extra plug on the radio harness, which dims. I use the 168 bulbs colored with a green marker, and the effect is just about stock looking. I tapped power for the EGT from one of the empty relay plugs on the dash fuse panel.
Old 10-12-2003, 10:59 PM   #6
enewtabie
Member#: 18928
2002 jdm wrx v7/v8
inter/w Spec C roof vent
I have all three of my gauges tapped into the clock..It can handle it..no problem
enewtabie is offline   Reply With Quote
Old 10-14-2003, 01:38 AM   #7
cre
Member#: 18153
2008 M3
thanks ... tapped there and no problems.
Old 10-14-2003, 10:24 PM   #8
enewtabie
Member#: 18928
2002 jdm wrx v7/v8
for about a year now..
Old 10-19-2003, 03:36 PM   #9
Schleppy
Member#: 15858
SPB
Can anyone link me to a wiring diagram for the clock harness? Which is +12v constant/switched? Which is ground, which is illumination...
Thanks!!
Schleppy is offline   Reply With Quote
Old 10-20-2003, 12:27 AM   #10
DjRez4
Member#: 18155
1985 4runner
AWD Pirates, Unite!
It's all labeled on the back of the clock
DjRez4 is offline   Reply With Quote
Old 10-20-2003, 09:57 AM   #11
Schleppy
Member#: 15858
SPB
I feel dumb.
Old 10-21-2003, 09:36 PM   #12
Zornorph
Member#: 17332
2004 Black STI
Not stock anymore
I had five tapped into that location for along time - no probs.
Zornorph is offline   Reply With Quote
help wiring up gauges where the clock use to be civichunter2 Electrical & Lighting 13 10-02-2006 05:32 PM
Help what wires on the clock do I tap for gauge wiring BIG BEN Electrical & Lighting 2 11-09-2002 01:04 PM
What is the best way to remove the clock housing? and tap wires for gauge lighting? NYWRXTASY Interior & Exterior Modification 10 11-03-2002 11:41 AM
gauge wiring clock wire ? help dark knight Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-14-2002 07:26 PM
Part number for the clock wiring harness jclick Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-21-2002 06:01 PM
