Old 10-12-2003, 05:53 PM   #1
m u f a s i s
Member#: 39817
2008 Evo X GSR
Rally Red
Exclamation In the middle of install, need help plz!
I'm installing a blitz dtt dc right now and i cant seem to find a good place to ground the black wires, i also am not shure where this pink wire is where the ebrake is, i only see a green wire. Please get back ASAP.
-Ryan
m u f a s i s is offline   Reply With Quote
Old 10-12-2003, 06:29 PM   #2
m u f a s i s
Member#: 39817
2008 Evo X GSR
Rally Red
Angry omfg
no one here can help me? ***! all i c is a green wire. im looking and i can see no pink wire
Old 10-12-2003, 08:05 PM   #3
sc00by71
Member#: 5362
2004 OBS
Green
where is it mounted ? a short path to ground is optimal. If you pop off the center console cover, lift up armrest and pop up undo mirror switch once in there you will see the single wire going to the switch on the ebrake. Tie into that wire.
hope this helps
Shawn
sc00by71 is offline   Reply With Quote
Old 10-12-2003, 08:07 PM   #4
pityr
Member#: 31719
Yeah, If you cant see the pink wire then you haven't tore the center console far enough apart yet.
pityr is offline   Reply With Quote
Old 10-12-2003, 09:43 PM   #5
enewtabie
Member#: 18928
2002 jdm wrx v7/v8
inter/w Spec C roof vent
See the bolts in the center of the hump..just loosen the bolt and slide the ground spade connector under..pink wire is sometimes hidden by insulation under the ebrake..its there..
enewtabie is offline   Reply With Quote
in the middle of a clutch install need help! htamotorsports New England Impreza Club Forum -- NESIC 17 11-08-2006 05:52 AM
in the middle of installing fuel pump on 05 I3oostedScooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-19-2006 08:36 PM
help again, in the middle of injector install. pics inside!!! help!!! VajraTLR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-01-2006 07:17 PM
quick help!!! in the middle of injectors install. VajraTLR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-01-2006 04:52 PM
Please Help, right in the middle of Blitz DTT DCII install w/ a problem HELP! relirex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-27-2003 07:46 PM
