Old 10-12-2003, 06:06 PM   #1
Fusionpnoy
Member#: 43752
Default Guage Clock
I got the OEM guage pack and was thinking of changing them soon. I was going to replace the boost, volt to bigger/better guages, but I don't care about the temp guage.
As you know, it the MY04 the center guages take place of the OEM clock, is there a company out there that makes a clock that would fit in a guage pod?
Thanks,
J
Fusionpnoy is offline   Reply With Quote
Old 10-12-2003, 08:05 PM   #2
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Afaik, most clocks are larger than the oem gauges. Check out www.egauges.com in case there is one that might fit, although I doubt it. It might be possible to hack the oem pod a bit to accomodate for a bigger gauge. Or replace the square center vents with smaller ones to make room for a clock.
http://forums.nasioc.com/forums/show...hreadid=352814
satrya is offline   Reply With Quote
Old 10-12-2003, 10:22 PM   #3
LinuxGuy
Member#: 17270
1998 Fender Bender
Holds 1000lbs.
Cheap and easy route....
$7.39 at pepboys, just sticks on with some double sided tape...
Norkskog makes a 2 1/16" LED Digital Clock, but you'd probably have lose a gauge and modify the opening to your pod.
LinuxGuy is offline   Reply With Quote
Old 10-15-2003, 02:16 PM   #4
Fusionpnoy
Member#: 43752
thanks guys for the feedback... will do. thanks
Old 10-15-2003, 03:00 PM   #5
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
Here's this one from Summit Racing for about $50 (52mm):
....and this one from Dakota Digital or about $150:
http://www.dakotadigital.com/Detail...umber=ODYR-16-1
Kean is offline   Reply With Quote
Old 10-16-2003, 01:12 AM   #6
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Or my VDO Vision clock:
FS VT: SPT Triple guage clock mount riderdude125 NESIC Private Classifieds 1 03-31-2010 09:29 PM
FS VT: SPT Triple guage clock mount riderdude125 Engine/Power/Exhaust 5 03-31-2010 09:29 PM
Oem Guage Pod, Autometer Procomp Ultra Lite Boost, Clock and Volt Guages mywaganiswhite SCIC Private Classifieds 42 10-26-2009 05:24 AM
Guage Clock Replacement 'clip' piece joehack98 Private 'Wanted' Classifieds 0 04-03-2007 09:18 PM
TT/Boast Guage in place of clock....Clock In air vent MY2ND04WRX Southern California Impreza Club Forum -- SCIC 4 03-05-2007 01:01 PM
