Welcome to the North American Subaru Impreza Owners Club Wednesday May 6, 2015
Old 10-12-2003, 11:01 PM   #1
fastenova
Member#: 38829
Not your usual 1997
Legacy GT
Default Rough idle and high-pitched whine at high RPMs
Lately, after cold starting my 97 Legacy GT, the engine has a low, rough idle and lacks power at ~1k - ~3k RPMs... Once the engine warms up, it runs as great as it always has. I have 110k miles on it, but have been running synthetic oil on it from the dealer.
I installed a Rallitek intake this summer and am just starting to get cold weather since I installed it... Could this have something to do with the low idle? Besides that, the engine is totally stock. Any suggestions on things to check out?
I have also recently noticed that at high RPMs under WOT, there is a whine coming from the engine compartment. It happens in gear and in neutral. Revving the engine with the hood open, I can't seem to hear it very much.
fastenova is offline   Reply With Quote
Old 10-12-2003, 11:45 PM   #2
simpreza2
Member#: 20381
04 Forester
Default Re: Rough idle and high-pitched whine at high RPMs
I have the same problem...my one friend told me to check the belts b/c it got colder out but i have yet to check them..im proabibly goin to tomarrow...but i dont know y else it would be making that squeal/whine
Jon
simpreza2 is offline   Reply With Quote
Old 10-13-2003, 12:41 AM   #3
atabert
Member#: 45107
1992 Legacy L
Green
Default noise
hopfully its not the trans pump?
atabert is offline   Reply With Quote
Old 10-13-2003, 03:12 AM   #4
BAC5.2
Member#: 43996
The Aggressive (tm)
You don't know about it..
Mine will occasionally do that, and I am bone stock.
Belts are fine on my car. So I don't know what the hell it is. If it does it, I usually stop and let her warm up or just drive really easily until I am up to OPP. Temp.
BAC5.2 is offline   Reply With Quote
Old 10-14-2003, 11:32 PM   #5
BJamerican
Member#: 5595
2005 Legacy 2.5GT
Satin White Pearl
Could your water pump be on it's last leg? I see you have 110K miles on the car. Water pumps can make whining sounds at certain RPMs when they are about to die, and the sounds are difficult to pinpoint in the engine bay. I doubt this would cause your rough idle though.
BJamerican is offline   Reply With Quote
Old 10-15-2003, 12:55 AM   #6
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
I'd recommend checking all of your vacuum lines to your intake and any of the other vac. lines in proximity to the installed intake. One that fit well "enough" while the weather was warm could very easily have contracted "back" now that it's colder and is causing a vac. leak.
Beyond that, it could be a bad coil pack, plug wire, plug itself, dirty/failing/failed idle air control valve, dirty throttle body, plugged Positive Crankcase Vent (PCV) valve, bad 02 sensor, fouled injector(s), plugged catalytic converter, bad gasoline, bad engine knock sensor and even a bad ground. At that age/mileage, any of these could be causal factors but I'd start with the vacuum lines and then move to the 1) ignition, 2) intake, 3) fuel delivery, 4) electronics, 5) exhaust in that order.
WRT the whine at WOT, could be the same vacuum leak, the belts and/or the water pump. If it's a vacuum leak and you locate/fix that, then you'll know whether that eliminated the noise or not. For the belts, try a little belt dressing (available at any auto store) just be very judicious and follow the directions so you don't over "wet" the belt(s). Check for coolant weep around the bottom of your bottom hose connector... could be the pump starting to go.
Alternatively, it could be your alternator bearing going as well. If the belts were too tight to start with, that would put undue load on the bearings and they could be failing, while the belt could now be slipping too.
Just a couple of quick thoughts.
Br, Dale
Subietonic is offline   Reply With Quote
Old 10-22-2003, 11:47 PM   #7
SUBE555
Member#: 24043
2005 Legacy GT Sedan
I also have a MY97 Leg GT, it has just started to intermittently whine in the 2000-5000rpm range (can't hear it above that.) It doesn't do it all the time, just generally more so in the morning or after it reaches normal temp for a few min after. It sounds like it's coming from the intake track as the harmonic/vibration generally, not always, goes away when I let off throttle, when I get back on throttle, generally it comes back. I have the STi tranny mount, so all NVH is more noticeable.
She's only got 76k on her but some rough miles and over the last 1-2 years, lots of city driving. I may just stop in at the dealer before I head out for the weekend, I have to stop in and talk to someone about something other than my car anyways. Those guys must hate me, ever since I had a shift fork replaced (yeah, don't ask), I've been in for this or that to make sure everything is on-par., hate to stop in again, but since I'm putting some 500+ miles on this weekend, probably a good idea. It's only been happening for the last two weeks, hopefully it'll last a little longer.
All input is appreciated and as I see, not alone on the NVH issues.
SUBE555 is offline   Reply With Quote
Old 11-18-2003, 10:21 PM   #8
TheLegacy
Member#: 47615
2007 BMW 335XI
Saphire Black
So anyone else get any answers... I just recently installed a BoMz intake, if anyone read about me having to get a T connector because I had only to bungs to the intake... Anway I have 2 sounds going on.
1 for fact I know are the brakes that I need to replace
second is a kinda girgle chatter (as if radio was on slightly in background, but its off). was wondering if it was vacuum or any of the 2 hoses I connected to the 2 connector (the 2 hoses that goes to the OEM manifold).
Oh and I to SOMETIMES hear a bit of a whine at like 1,000-1,500 RPM
Thanks
TheLegacy is offline   Reply With Quote
Old 11-19-2003, 12:32 AM   #9
andyC
Member#: 1607
2002 Silver
double you are ecks wagon
That's what I would check also!
andyC is offline   Reply With Quote
Old 11-20-2003, 02:18 PM   #10
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
Are you sure the whine isn't just the intake? I installed a Rallitek intake and it was obscenely loud at high rpm's, but not when I rev the engine in neutral.
whtlegacy is offline   Reply With Quote
Old 11-21-2003, 02:50 PM   #11
MikeKlacy
Member#: 47775
2005 LGT Wagon
Regal Blue Pearl
Legacy
It might be ice collecting inside the skorkel(silencer0
And the low pozer might be the moisture in the air when your car isnt warm.
MikeKlacy is offline   Reply With Quote
high pitched whine at idle theostubbs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-01-2012 04:50 PM
High-Pitched Whine, Stereo/RPM dependant stiIV Car Audio, Video & Security 5 11-26-2005 11:14 PM
High Pitched Whistle at 3K RPM FD777 Newbies & FAQs 23 08-16-2005 07:20 PM
high pitched whining at 120mph+ drunkguy Transmission (AT/MT) & Driveline 23 01-25-2004 08:39 PM
High pitched wistle at high RPM when under boost. roybfr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-15-2003 12:22 PM
