Old 10-13-2003, 12:53 AM   #1
The Donnn
Member#: 33178
SQC 106
Default RPM sensor wire on STI ecu ?
i am trying to hook up a t-sport rev light, and i need to splice into the rpm sensor wire at the ecu. does anybody know its location ?
The Donnn is offline   Reply With Quote
Old 10-14-2003, 12:11 AM   #2
brunetmj
Member#: 8023
2004 2.5 RS
Does it have to be off the ECU? The back of the gauge cluster works just fine and is a whole lot easier. The tach wire can be picked up on connector I10. This connector (I10) , is the only ten pin connector of the three connectors on the back of the gauges. The tach wire is A5 on the connector I10. It is a green wire.
brunetmj is offline   Reply With Quote
Speed Sensor Wire On 2006 STI Bennett Car Audio, Video & Security 21 10-12-2006 11:54 AM
Rear o2 sensor wire on a 2000 2.5rs LB2.5rs Electrical & Lighting 2 08-15-2003 11:42 PM
Rear O2 sensor wire on '02 WRX? andygold Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-10-2002 11:05 PM
apexi tt What wire on the ecu is for the 02 sensor REDOO2000 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-15-2001 01:38 AM
new Q: where the speed sensor location on the ECU? pbnj9786 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-06-2001 11:21 PM
