Old 10-13-2003, 03:02 PM   #1
jeff22
Member#: 7534
99 impreza rs-t
rally blue pearl
Default GM part # for a 3 bar MAP sensor
Looking to turn up the boost anyone know the part # for the 3 bar pressure sensors from GM?
jeff22 is offline   Reply With Quote
Old 10-13-2003, 03:34 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
MAP sensor (two Bar)
16040749
MAP sensor (three Bar)
I don't have the pigtail part numbers, though, sorry. You might be able to get one out of a junkyard, though, just go in find one and snip it.
Old 10-13-2003, 07:22 PM   #3
boysetsfire
Member#: 6218
2001 2.5rs-t
silverthorn metallic
this is the number on what i was told was a gm 3-bar map sensor
16254539 but when put into gmpartsdirect.com it just says its a computer control sensor and has not other description.
Edit: Did a search and found out that is the new part number for the 2 bar map sensor.
-Marc
boysetsfire is offline   Reply With Quote
Old 10-14-2003, 03:32 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
watch out .. i tried to order a 3 bar and ended up with a 2.5 bar (useless on a tec 2)
Old 10-14-2003, 05:28 PM   #5
jeff22
Member#: 7534
99 impreza rs-t
rally blue pearl
2.5bar? they make a 2.5 bar sensor? i just want to turn it up 4 more pounds or so. it won't work on on the tec2
Old 10-14-2003, 09:14 PM   #6
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
With which part number?
Old 10-14-2003, 10:27 PM   #7
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
will the 2.5 work the the tec 3? i will trade ya the 2.5 for my 3.0
subiekid is offline   Reply With Quote
Old 10-15-2003, 06:52 PM   #8
jeff22
Member#: 7534
99 impreza rs-t
rally blue pearl
I picked a MAP sonsor from edwin at ffteng.com and it will not let my car run past idle the KPA screen on my tec is good but it must be the 2.5bar sensor or something. just have to wait to turn up the boost thanks for the help
Old 10-16-2003, 02:08 PM   #9
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
well the way to tell is to install the sensor change the sensor paramater to 3 bar
turn the key to on (don't start)
go into monitor mode
see if the kpa is at or near 100
if its is above 100 then it is a 2.5 bar sensor
it can be used ... you just have to adjust your kpa values (icky)
Old 10-17-2003, 04:19 PM   #10
jeff22
Member#: 7534
99 impreza rs-t
rally blue pearl
It is the 2.5bar sensor and i did adjust the KPA graph but it still does not run with that sensor.
Old 10-17-2003, 05:18 PM   #11
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Guys, which is the 2.5bar sensor? I don't want to leave the incorrect part numbers up there if other people want to order the sensors as well...
Old 10-18-2003, 11:17 PM   #12
subiekid
Member#: 25516
PART 1604749
LOT 12H1204A
those are the numbers on mine.
Old 10-20-2003, 02:16 PM   #13
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
nick ill try and look tonight
i got discusted and put it "somewhere"
04-06 sti Utec w/ map switch, gm 3 bar map sensor for speed density & tatrix cable methaddict Engine/Power/Exhaust 26 07-12-2008 12:47 AM
04-06 sti Utec includes map switch, gm 3 bar map sensor spd density & tatrix cable methaddict SCIC Private Classifieds 19 07-12-2008 12:47 AM
GM 3-bar map sensor with utec deluxsti Engine Management & Tuning 7 11-01-2005 03:17 PM
gm 3 bar map sensor White 2.5rs Private 'For Sale' Classifieds 9 10-09-2005 11:45 AM
GM 3-Bar Map Sensor EVOBOXR Engine Management & Tuning 2 04-02-2005 09:35 PM
