Old 10-13-2003, 06:19 PM   #1
4kornerz
Member#: 43073
2004 STI
Java Black
Default Where's the headlight adjusting screw on my STI?
I know it's in there somewhere...does anybody have a pic?
Thanks
4kornerz is offline   Reply With Quote
Old 10-13-2003, 06:24 PM   #2
dsmperformance
Member#: 15059
2004 WRX STi
1991 TSi
Did you know you can adjust the beam level from inside the car?
dsmperformance is offline   Reply With Quote
Old 10-13-2003, 06:30 PM   #3
4kornerz
Member#: 43073
2004 STI
Java Black
Yes I did.
My car is lowered and has a little more rake than stock so the lights are now too low.
Old 10-13-2003, 06:33 PM   #4
Silver-Bolt
Member#: 40189
2004 STi
Silver/Silver
I just did this to mine. For the HID STi lights it's a small white nylon hex adjustment screw on the back of the housing. You will be adjust the beam, not the housing. Typically when a traditional headlight is adjusted the entire assembly is adjusted up or down & left or right. The HID adjustment only raises the beam pattern.
Silver-Bolt is offline   Reply With Quote
Old 10-13-2003, 06:40 PM   #5
4kornerz
Member#: 43073
2004 STI
Java Black
Cool,
I saw that.
It looks like a phyllips screwdriver will fit from the top down into the adjusting gears will that work?
I tried turning the nylon hex but there's little room...
Old 10-14-2003, 03:17 AM   #6
TurboPhoon
Member#: 5946
To adjust the headlight beam, first look at the back of the headlight and you will see a circular piece of toothed metal. Only part of it is exposed. On the bottom of this more of the piece is exposed, rotate that with your finger and you will see the beam move.
TurboPhoon is offline   Reply With Quote
Old 11-14-2003, 09:47 PM   #7
D-I-Z-Z-L-E
Member#: 37178
1960 Stdbaker champ
rust
ok people. this can be done 2 ways. the teeth on the adjusters are for a phillips screw driver. you put it in the slot above the teeth and it ligns up with them. then you turn the screw driver and it will lower or raise the beam. also the left to right on the high beams also moves the hid's
D-I-Z-Z-L-E is offline   Reply With Quote
Help with the Cobb Short shifter on my STi NorCal06STi Transmission (AT/MT) & Driveline 9 09-20-2015 02:29 PM
painted the exhaust and badges on my sti bugsti Member's Car Gallery 26 04-18-2008 04:44 AM
Where is the other headlight adjustment screw? hklaine Legacy Forum 3 03-24-2004 12:13 AM
Did I get screwed on my STi shifter Trim? juztin180 Interior & Exterior Modification 32 01-02-2004 11:41 AM
