Old 10-13-2003, 08:16 PM   #1
essogas
Member#: 35703
2004 WRX STi
Blue/British Black 18's
Default What size torque wrench for STi wheels and lug nuts
I don't know if it's 3/8" or 1/2" I need. I imagine it's 1/2" and torque is 58-75 foot pounds. Thanks
essogas is offline   Reply With Quote
Old 10-13-2003, 09:33 PM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
The size is up to you. You only need to torque the wheels to about 70 lb-ft. If you have 3/8" sockets, then go with the 3/8" torque wrench and vice-versa. Or, you could just buy both as I did.
Calvin
cnk is offline   Reply With Quote
Old 10-14-2003, 12:51 AM   #3
filbert
Member#: 39661
2004 WRB WRX STi
07 OBP FXTS
my torque wrench was 1/2" but all my sockets are 3/8" Luckily my torque wrench came with a 1/2"-3/8" adaptor so no problems.
I use a 1/2" breaker bar to loosen the bolts, a 3/8" socket wrench to remove and replace them, and a 1/2" torque wrench to re-tighten them.
filbert is offline   Reply With Quote
Old 10-14-2003, 02:33 PM   #4
Tire Rack Moderator
Member#: 1215
ext. 4362
when using an adapter you need to increase your torque setting by about 5 ft. lbs. because they do flex abit in the connecting joints ....
just a heads up
what size torque wrench/socket? keepclam Service & Maintenance 5 06-06-2010 02:03 AM
Speedline wheels and lug nuts kevinsUBARU Motorsports 2 01-30-2006 05:36 PM
What size torque wrench for suspension work? SoLiDbReAkZ Service & Maintenance 4 06-11-2002 01:13 AM
Rota Wheels and lug nuts Q's? gpd323 Brakes, Steering & Suspension 2 04-05-2002 06:50 PM
What size allen wrench for top strut shaft and hex wrench to hold the shaft?? please GregBolby General Forum Archive 3 02-13-2001 03:29 PM
