Old 10-13-2003, 08:37 PM   #1
CRS9
Member#: 7175
1999 Impreza 2.5RS
Question Question about front end link install
I just installed my Whiteline front end links tonight, and I got a quick question. On the lower bolts, I cannt seem to tighten them. It looks like they just keep spinning on the nut. I used all the all washers and everything went together fine. Is this normal behavior for these bolts?
Thanks for any info
CRS9 is offline   Reply With Quote
Old 10-14-2003, 06:10 PM   #2
CRS9
Member#: 7175
1999 Impreza 2.5RS
Default ???
Anyone?
Old 10-14-2003, 06:26 PM   #3
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
You mean the nut keeps spinning on the bolt? Sounds like you stripped it. Is this happenning on both sides?
Old 10-14-2003, 06:30 PM   #4
CRS9
Member#: 7175
1999 Impreza 2.5RS
Default Ya
Ya, it's happening on both sides. I didnt even get to a point where they were that tight. That's why I didnt think I stripped them
Old 10-14-2003, 06:37 PM   #5
ConeMasher
Member#: 2135
Forgive me if I'm stating the obvious, but the stock bolts require the use of an allen key to hold it in place while you work the other side with a wrench. Perhaps this is your problem.
-- Gary
ConeMasher is offline   Reply With Quote
Old 10-14-2003, 08:36 PM   #6
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
-- Gary
Gary, he has an RS, GC8, no Allen bolts there.
CRS9- did you use the supplied washers? I can't remember, but are the bolts the same length? I know that the top one's use a larger head compared to the bottom bolt. You may have a longer one on the bottom, hence its not allowing you to tighten down all the way. Take a look.
Arnie is offline   Reply With Quote
Old 10-14-2003, 09:14 PM   #7
CRS9
Member#: 7175
1999 Impreza 2.5RS
Unhappy Stripped
You were right the first time Gary...I stripped both of them. I had to Dremal them off and replace both bolts and nuts. Thanks for the help!!
Old 10-15-2003, 03:48 AM   #8
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Argh, what a bummer. but at least the hardware is relatively standard and can be replaced with another nut and bolt. did you cross thread them, or what?
Old 10-16-2003, 02:59 AM   #9
CRS9
Member#: 7175
1999 Impreza 2.5RS
I must have cross threaded them somehow. I tried backing them out with pressure to the end of the bolt and all it did was strip more thread. When I finally got them cut off, there was about 3/16" of thread stipped. I have no idea how I did it cause I never applied that much pressure to them. Oh well, I got the new ones in nice and tight.
Kartboy end link install question gopsu Newbies & FAQs 0 06-07-2009 02:16 PM
FS - AZ: 06 STi f&r swaybars w/end links and BNIB Perrin front end links bObby Suspension/Brakes/Handling 7 05-19-2009 09:48 AM
Front end link installation gopsu Newbies & FAQs 8 05-08-2009 10:06 PM
FHi 20mm rear sway bar and Kartboy end links install question nuggetWRX Brakes, Steering & Suspension 11 08-11-2008 09:14 PM
tell me about your Kartboy front end links Darryl Brakes, Steering & Suspension 15 05-31-2007 12:57 AM
