Old 10-14-2003, 01:41 AM   #1
Se3n
Member#: 14268
2003 WRX
Midnight Black
Default adjusting Morettes?
I just installed the Morettes I got from subiegal and I noticed driving around that they were aimed way too high. I assume they're adjustable... but I don't feel like going back out there. So I figured I'd ask so maybe I can do it quick in the morning before I go to work. Thanks guys.
Se3n is offline   Reply With Quote
Old 10-14-2003, 07:58 AM   #2
Nick Martin
Member#: 32080
2002 impreza wrx
wr blue
All ECE headlamps can be aimed manually.
You should have 1/2 tank fuel and usual load carried under normal driving conditions.
Make sure tyre pressures are correct and that the ground your car is on is level over the distance to your vertical reference surface (usually a wall).
Required
a) something to mark your surface.
b) tape measure.
c) plumb bob
d) electrical insulation tape or something similar you dont mind sticking to your car temporarily
e) A second person is helpful for marking out the dimensions
Lights should be aimed in the "dipped" or low beam mode.
Tech reference:
Each headlamp unit will have a reference point marked on the lense of the unit in fromt of the low beam bulb. This could be a dot, cross, bulb type designation or brand name.
This is its "axis" and the point from which measurements relate.
The first thing to do is to determine the height of the axis of the headlamp as installed on the car.
Measure the distance to the ground and make a note.This measurement determines the amount of downtilt required.
Headlamp axis height Downtilt Required
800mm or less 76mm
801mm to 999mm 101mm
1000mm or higher 114mm
The next thing to do is lay out the "geometry" required for aiming.
1)The vehicle should be parked perpendicular to the reference surface with the headlamp axis point 7620mm horizontally from this surface.
2)Measure the horizontal distance between the two headlamp axis marks, divide by two and this gives the distance of the axis' from the centre line of the car. Note this measurement and Mark this point on your car bonnet with the electrical tape so that you can see the tape when looking through the car from behind.
3)At the rear of the car, measure the width of the rear window, and mark the centre of it with tape. (there may already be a central logo or similar that you can use as a reference point)
4)From behind, sight through the glass and align the two reference marks. With your second person, get them to mark the point on the wall where this line (projected) meets it.
This gives you the vehicle centre line reference on the wall.
5) with the plumb bob mark the vertical surface through this point from ground level up to at least the headlamp axis height.
6)Where this vertical line meets the ground measure horizontally the distance previously measured on the vehicle as the horizontal axis distance ( using 1/2 this measurement either side of the vertical line) to give you the horizontal location of the Axis points on the wall.
7)Using the plumb bob measure vertically upwards from the points marked in (6) to give you your reference axis points on the wall.
Mark these points (A) and mark a horizontal line between the two.
Measure down from these points (using the table above to determine the required downtilt) and mark this points "D" . Join these points with a horizontal line.
You now have all the reference points reqiured>
==A==================+=================A==
==D==================+=================D==
_____________________________________________glvl
Turn your lights on!
Vertical Aiming:
The low beam pattern has a distinct horizontal cut off between light and dark. Below the cut off is bright and above it dark. The headlamp should be aimed so that this horizontal cut off is along the line "D-D".
Horizontal Aiming:
The low beam pattern (on RHD car light units) kinks upwards on the left hand end of the light pattern \__ (on LHD the opposite__/).
This kink point for each light unit should be aimed so that the apex of the kink in its light pattern is on the intersection between the line through "D-D" and the vertical line through its respective "A" mark..
This is spot on aiming.
There is a tolerance of +/- 50.8mm in the horizontal aim. Moving the kink point right (RHD in the UK) will increase your sight down the road under low beam conditions but you will then become susceptible to dazzling the oncoming traffic.
I hope this helps & the diagram above sort of works
Nick
Nick Martin is offline   Reply With Quote
Old 10-14-2003, 08:05 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Nice E-code aiming procedure but I think he was asking where the specific adjusters are on the Morettes.
Behind the low beam/ projector unit you'll see some plastic hex head screws. Some will have white caps on them, don't disturb these. There are two uncapped ones opposite each other, these the the ones you need to adjust. The one on the inside (nearest the high beam) is a somewhat diagonal adjustment that moves the beam both horizontally and vertically at the same time. Adjust that one first to set the horizontal position of the "kink" point where the beam starts to rise. The one on the outside is for vertical only, adjust this one last to set the beam height.
The adjusters are easier to turn if you place the proper size 1/4" socket over them and use your fingers to turn the socket. No ratchet or extension is needed.
Old 10-14-2003, 12:06 PM   #4
Se3n
Member#: 14268
2003 WRX
Midnight Black
Nick, that was a great post. But mulder was right, I was just wondering where the adjusters were. Thank you both, you guys rock.
Sean
Old 03-24-2005, 07:48 PM   #5
voyagerman
Member#: 42133
2002 Impreza WRX
Rally Blue Pearl
Good to read that i installed HID in my morettes and really needs an adjustment
people in the street are going to kill me.
voyagerman is offline   Reply With Quote
Adjusting Morettes quazimoto Electrical & Lighting 9 03-24-2014 05:09 PM
How do I adjust Morettes? Orson Electrical & Lighting 8 02-20-2003 08:52 AM
morette adjustment wwp8 Interior & Exterior Modification 2 01-30-2003 09:41 PM
Adjusting bolt for Morettes RallyX13 Alaskan Impreza Club Forum -- AKIC 1 09-12-2002 01:33 AM
