Old 10-14-2003, 11:10 PM   #1
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
Default Suspension Questions for the 2000 Legacy
I got a 2000 Legacy GT Limited, would the following items work for my car? Also, i know how to install the front strut tower brace, but how do i do the rear one? Should I get an anti sway bar as well?
http://cobbtuning.com/legacy/suspension.html
I was looking at possibly getting the first 3 items on that page, later on, getting sport springs...
Acejam2k is offline   Reply With Quote
Old 10-14-2003, 11:34 PM   #2
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
From experience, I don't believe the front strut brace does a lot. The rear definitely seems to have an impact on my 2k Legacy wagon, though. I definitely advise getting a swaybar for the rear, but you won't find one at COBB. They've had troubles sourcing a good bushing, and refuse to sell the bars in stock with bushings they don't feel are quality, even if it means customers buy bars elsewhere!
LetItSnow is offline   Reply With Quote
Old 10-15-2003, 12:31 AM   #3
TGycageL0002
Member#: 9116
2000 Legacy
Timberline Green Pearl
just to save you the ehartache and toruble..... anything marked for use on the wagon as far as springs go WILL NOT WORK ON YOUR CAR.. WAGON PARTS ONLY WORK ON THE WAGON...
when you get ready to buy the springs, let me know and i will dig up the part numbers form whiteline
TGycageL0002 is offline   Reply With Quote
Old 10-15-2003, 02:56 AM   #4
NiTRoN
Member#: 30556
2000 Legacy GT (BE)
over 250,000 Miles
Keep in mind.. Sedans don't have rear strut towers.. shocks are bolted right onto the body floor.. you can check it yourself.. just remove covers in the corners (the side wall ones) just behind the back seats and you will see 2 bolts and plastic round cover on the floor..
If you want to stiff en up your car get the rear swaybar.. or even KYB-GR2 shocks and some new springs..
I recently replaced all my stock shocks with GR2s and there is huge difference.. I'm still using stock springs..
NiTRoN is offline   Reply With Quote
Old 10-15-2003, 09:24 AM   #5
djplegacy
Member#: 33367
2008 Legacy GT Limit
QSM
Nitron, where did you buy your new struts?
Thanks,
David.
djplegacy is offline   Reply With Quote
Old 10-15-2003, 05:07 PM   #6
NiTRoN
Member#: 30556
2000 Legacy GT (BE)
over 250,000 Miles
Thanks,
David.
www.kybstruts.com
if you need part numbers for 2000 Legacy GT sedan.. leme know and I'll post em here.. or you can download the catalog part locator
http://www.kyb.com/downloads/kyb_multiview.zip
Old 10-15-2003, 06:48 PM   #7
Jason
Member#: 105
2000 Legacy GT Ltd
WHT
I had luck with japanese springs on Legacy GT sedan.
You will need to change the front spring plate to Impreza one though since US version has a larger diameter plate.
I used Tein, kg/mm and both work just fine.
I do recommend performance strut though.
Jason is offline   Reply With Quote
Noob suspension question for the gurus... borf42 Brakes, Steering & Suspension 1 10-01-2005 02:49 AM
Tein suspension questions for the GC8 underground-mpyre Brakes, Steering & Suspension 6 04-17-2005 12:57 PM
Suspension question for the 18 millionth time MitchGT Legacy Forum 15 03-21-2005 02:56 PM
suspension question for the master techs: bushing differences between FWD/AWD? RaceCarRiot Brakes, Steering & Suspension 2 05-14-2002 09:08 AM
Another suspension question for the class gtguy Legacy Forum 3 11-06-2000 12:26 AM
