Welcome to the North American Subaru Impreza Owners Club Friday October 28, 2016
Old 10-15-2003, 12:07 AM   #1
Member#: 2173
2005 LGT Wagon 5MT
Exclamation Help: Squeaky/Creaky noise from clutch pedal...
This happens when I depress the clutch pedal. I can hear it inside the car and als when I stick my head out the door. Any ideas about what may be going on and how might I be able to fix it?
Robmat is offline   Reply With Quote
Old 10-15-2003, 01:47 AM   #2
Member#: 28716
2006 STI
Maybe your clutch linkage just needs some lube. I would get under there with a flashlight and push down on the clutch pedal with your hand to try to pinpoint the noise. Those sprays that set into grease work the best.
esteve is offline   Reply With Quote
Old 10-15-2003, 12:23 PM   #3
Member#: 34832
1989 M3
mine does It as well, asked dealer to fix it when i was in for the clutch TSB, but they didnt next time Im under i'll lube it up and hope for the best, Its not all that loud on mine but audible over my exhaust
elsanto is offline   Reply With Quote
Old 10-15-2003, 03:41 PM   #4
Member#: 8225
On my Legacy it was the clutch fork pivot point inside the bell housing. It quieted down after I dripped some Breakfree lube down some aquarium tubing into the pivot point. It helped for a while, but it had started squeaking again a couple thousand miles later. When my clutch was done, the shop cleaned and lubed it with some heavy grease. All good now. Hope it lasts.
kturner is offline   Reply With Quote
Click noise from Clutch Pedal? krinksta Newbies & FAQs 34 11-22-2011 08:03 PM
Humming Noise when clutch pedal is not depressed airspeed Transmission (AT/MT) & Driveline 7 08-11-2008 01:40 PM
squeaking noise from clutch pedal? sjw Newbies & FAQs 5 05-28-2004 09:10 AM
"Spring" or "Rattle" noise from clutch pedal bjteel Warranty Issues & SOA Problems 7 05-30-2002 03:17 PM
Strange noise from clutch pedal 555wagon Normally Aspirated Powertrain 7 02-21-2001 12:45 AM
