Bay Area Impreza Club
Go Back   NASIOC > NASIOC Chapters > Bay Area Impreza Club Forum -- BAIC
Old 10-15-2003, 01:09 AM   #1
Kickz107
Member#: 25850
2003 Infiniti M45
Default I need strong 2x sided tape!
So I need to really strong double sided tape for my rear oem lip and my Defi control unit. For some reason the stuff I had is too weak. Who makes extremely strong double sided tape and where can I get it?
Chris
Kickz107 is offline   Reply With Quote
Old 10-15-2003, 01:39 AM   #2
nate49509
Member#: 22452
2016 WRX
3M makes this white double sided adhesive that used for hanging stuff on walls. You can find it at places like Home Depot or Lowes. I friend from work used it to hang his phone on the wall and when he went to remove it a piece of the drywall with it.
nate49509 is offline   Reply With Quote
Old 10-15-2003, 02:33 AM   #3
FryRice
Member#: 38402
2004 WRX~vf34 SOLD
EVO MR
I have the red kind from 3M, when you are using these tapes be sure to use rubbing alcohol to get that grease out if you dont they will not stick!
FryRice is offline   Reply With Quote
Old 10-15-2003, 07:24 AM   #4
JSiwek
Member#: 14909
Yeah 3m's super strong outdoor stuff (gray tape w/ red plastic peel-off part, smells like starfruit) is insanely strong, especially after it has been stuck to something for a while. You can find it at Home Depot...
JSiwek is offline   Reply With Quote
Old 10-15-2003, 11:34 AM   #5
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Go to a hobby store and ask for servo tape. That ish is strong. Usually it's about 1/16" or 3/32" thick foam.
If you're in the South Bay, try Sheldon's hobbies on Oakland Road Just south of Montague.
I don't know which brand is strongest, but I bet the guy behind the counter does.
Yes, always clean the surfaces with alcohol. I use denatured alcohol (ethanol), but rubbing alcohol (isopropanol) works too.
Concillian is offline   Reply With Quote
What is the best way to get this strong 3m doubleside tape off? Un0RiGiNaL Interior & Exterior Modification 18 04-10-2009 10:01 PM
Need Double Sided tape for Chargespeed Roof Fin? Jon347 Interior & Exterior Modification 5 07-21-2006 04:20 PM
need help removing doubled sided tape drain bramage Interior & Exterior Modification 8 07-17-2005 09:58 AM
Where to find strong double-sided tape? SWRX Interior & Exterior Modification 12 11-21-2004 12:47 PM
PLZ HELP: Where to get **3M** or STRONG Double Stick Tape...Been 2 Home Depot, Kragen clsmooth71 Bay Area Impreza Club Forum -- BAIC 6 02-16-2003 06:49 AM
