Welcome to the North American Subaru Impreza Owners Club Saturday April 25, 2015
Old 10-15-2003, 01:58 AM   #1
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Default Cam sprockets hard to remove?
Okay so we were moving some stuff over from my old engine to the new engine. It required I remove the old cam sprockets (rear timing belt cover). The left hand side ones weren't all that hard to remove, I know the specs in the manual say 72 ft-lbs. The right hand side ones are a different story. They wouldn't budge. I broke out the 600 ft-lb IR impact and they didn't budge. The day ended when I used a 1/2" breaker bar and ended up snapping a 10mm Craftsman hex socket. Am I missing something obvious?
Old 10-15-2003, 06:18 AM   #2
2superblus
Member#: 33526
2013 WRB W/Gold BRZ
08 STI WRB w/Gold, 02 WRX
I'll talk to lance he recently took his a part. I'll see what tricks he used.
Bart
2superblus is offline   Reply With Quote
Old 10-15-2003, 08:05 AM   #3
2000vfr800
Member#: 15599
No...you aren't missing anything. They are on EXTREMELY tight.
2000vfr800 is offline   Reply With Quote
Old 10-15-2003, 10:36 AM   #4
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
Hmm, mine were tight, but not THAT tight. I put a breaker bar on the end of a craftsman hex bit, and used a crecent wrench to hold the cams in place. It took a bit, but they all came off.
-C
TypeC is offline   Reply With Quote
Old 10-15-2003, 11:01 AM   #5
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Some of those engine bits (ie: camshaft sprockets and crankshaft pulley) are notiorious for being "seized" into place. Due to the constant heat cycling and torques applied due to the belts, they work their way down into a tight little spot and are very hard to get off.
-Jon
Old 10-15-2003, 11:14 AM   #6
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Yeah we tried to get a generous amount of PB Blaster in there and we'll see what happens later when I try to get it off. It was just strange how only the one side is like that, but it's both sprockets, the others came off with the impact like nothing. We were using the same method with holding the cam with a wrench and then using the impact or breaker bar on it.
Old 10-15-2003, 11:19 AM   #7
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
3/8" hex socket snaps like a twig. We had to use a 1/2" hex socket and then we got it off by using a wrench on the cam to keep it still, and a BIG breaker bar on the other side with the socket.
Yeah... you kinda learn after taking 3 apart
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 10-15-2003, 11:52 AM   #8
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
One little trick we did was broke the nuts with the timing belt still on. That way, all we had to worry about was how big the breaker bar was.
-Jon
Old 10-15-2003, 01:41 PM   #9
STEALTH-WRX
Member#: 7822
Multi layer snot green
Mine were rediculously tight. It took three guys. One to hold the motor on the stand and two to crank on.
STEALTH-WRX is offline   Reply With Quote
how hard to remove intake manifold?? skate enjoi Interior & Exterior Modification 7 09-14-2006 02:34 PM
Any other ways to remove the cam sprocket on a sti without a special tool? ride_the_pony69 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 09-09-2006 05:20 PM
How hard to remove heat shield on cilinder #4 for EGT??? BBBsti LTD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-26-2005 03:25 PM
Differential fill & drain plugs hard to remove - torch 'em? NotFast Service & Maintenance 15 11-17-2003 07:12 AM
How hard to remove/install rear bumper?q AWDconvert Bay Area Impreza Club Forum -- BAIC 2 05-08-2003 10:42 AM
