Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 10-15-2003, 05:10 AM   #1
Scoobiedo0
Member#: 43266
04 wrx
wrb
Default Best philllips based hid kit?
I am in search for a H1 6000k H.I.D conversation kit witch uses phillips capsules and ballast for my 04' WRX reflector head lights.
Funny thing is that the other day i went to a retail shop where they tried installing a H1 hella ballast H.I.D kit using relays and everything on my 04' seemed not to work. The lights were completely dead but when they wired it stright from the battery there was reponse. This inccident has never occured to them and there suggesting is that it has something to do with the ECU. I have a freind that drives a GDA WRX that has a phillips kit from
" Polarion " and was a perfect fit for his GDA.
Does anyone know what my problem is?,and any advice on what H.I.D kit i should own?
Thank you
Scoobiedo0 is offline   Reply With Quote
Old 10-15-2003, 06:48 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Was the shop aware of how the Subaru headlight system works? It is a common positive, switched ground system. If they didn't know this and had no info regarding the wiring that would explain why they couldn't get it to work.
Ground the ballasts directly, and connect the positives to the common headlight power. They should work. If you want to add the relays the only place they should be used is on the positive side to switch the power from the battery but as long as you have the direct ground the relays aren't essential.
PM me if you want to discuss this further.
Which HID kit should I get, who makes the best kit? Jay04WRX Electrical & Lighting 29 10-12-2003 07:38 AM
What is the best Dual Beam HID kit? dRu888 Interior & Exterior Modification 11 01-08-2003 10:48 PM
Best HID kit? TonyWRX Interior & Exterior Modification 40 10-16-2002 03:22 PM
Best place to get a 4300K HID kit from? Schleppy Interior & Exterior Modification 3 08-31-2002 02:46 PM
what's the best HID kit? rbehny Interior & Exterior Modification 12 11-12-2001 11:59 AM
