Old 10-15-2003, 07:47 AM   #1
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Default Needed: Pictures of Legacy Turbo 5spd Trans
Hello Everybody. I am doing some research on the older turbo Legacy's 5spd trans and was wondering if anyone has pictures of one. They can be an underneath shot of it on your car or more preferably a couple pictures of it taken out of your car showing all angles.
I know its asking a lot but hopefully somebody has a few shots.
Brad
MY99 2.5GT is offline   Reply With Quote
Old 10-15-2003, 01:29 PM   #2
outback2.5HO
Member#: 15135
95 GF WRX
It should look the same as your GT tranny with maybe the exception of the rear output shaft.
What are you planning on doing?
outback2.5HO is offline   Reply With Quote
Old 10-15-2003, 01:53 PM   #3
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
I am looking for close up pictures of the turbo trans to find seems or case design variances that would shed some light on whether or not the case is stronger then the newer USDM SOA 5spd trans.
Brad
Old 10-15-2003, 02:03 PM   #4
outback2.5HO
Member#: 15135
95 GF WRX
OK...
Next time I rack my '93, I'll shoot some pics for you.
Old 10-15-2003, 03:10 PM   #5
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
"rack"
Are you planning to stick a new steering rack in sometime soon?
Is your 93 a turbo legacy?
Thanks
Brad
Old 10-15-2003, 03:12 PM   #6
Jarvis
Member#: 8267
2010 MB E63
Black on Silver
"Put it up on a rack (i.e. car lift)" I'll bet.
Jim
Jarvis is offline   Reply With Quote
Old 10-15-2003, 03:43 PM   #7
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
That would make more sense. Never thought of it as a rack. Always referred to it as a lift or jack.
Old 10-15-2003, 03:59 PM   #8
outback2.5HO
Member#: 15135
95 GF WRX
What Jarvis said...
Yes, it's a Turbo.
Old 10-15-2003, 06:35 PM   #9
Kha0S
Member#: 8808
2011 WRX
DGM 5D
Caution ... it has me giving the transmission "the finger," but here it is:
http://strange.net/images/trannyswap.jpg
/Andrew
Kha0S is offline   Reply With Quote
Old 10-15-2003, 08:42 PM   #10
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
how is the outside of the trany gona make it stronger?
subiekid is offline   Reply With Quote
Old 10-15-2003, 09:33 PM   #11
sovereignmk1
Member#: 11858
1998 Silver Legacy
/Andrew
What a beautiful picture
//M
sovereignmk1 is offline   Reply With Quote
Old 10-16-2003, 03:25 AM   #12
biggreen96
Member#: 12535
vf39 06 5MT XT
92 Legacy Rally EG33'd
if the tranny case is beefier then it doenst flex as much when power is running through it, when it flexes the gears push away from each other and they strip.
biggreen96 is offline   Reply With Quote
Old 10-16-2003, 07:49 AM   #13
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
Green's got it!
Many people think that the solution to the common problem of stripping gears in highly modified wrxs is to replace the gear set with a much stronger dog box or MRT unbreakable syncro gear set.
Unfortunitely this couldn't be further from the truth. The stock subaru gear set is super strong but the case isn't. Thats why people with dog boxes and the MRT gears still report stripping gears. The weak point is the trans case. It flexes just enough when a large amount of torque is applied to the input shaft quick enough it causes the case to flex and expand just enough to cause the gear teeth to not fully sit in each others grooves. When the gear teeth only half way contact each other and are recieving 300+ lb ft of torque teeth start breaking.
Brad
Old 10-16-2003, 11:12 PM   #14
Kohburn
Member#: 43493
99 Legacy GT Limit
novel thought here i'm sure - but the case is cast aluminum i assume.. why not bend/cut reinforments and weld them to the case
Kohburn is offline   Reply With Quote
Old 10-17-2003, 07:48 AM   #15
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
Easier said then done.
You can buy a case brace from MRT but they are upwards of $2500. I haven't seen how they designed it but I am assuming the brace is formed around or molded to fit every little noock of that trans so it doesn't give at all.
Brad
Old 10-17-2003, 08:56 AM   #16
etam
Member#: 439
www
etam is offline   Reply With Quote
Old 10-17-2003, 08:57 AM   #17
etam
Member#: 439
www
are you guys saying that 6speed case is much stronger than 5speed case? or total different story here..
Old 10-17-2003, 09:02 AM   #18
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
Thanks etam. What trans is that?
The STI 6 speed supposedly has a redesigned case that solves the flex problem.
Old 10-17-2003, 09:47 AM   #19
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
I wish they'd just redesign the 5spd case...
IronMonkeyL255 is offline   Reply With Quote
Old 10-17-2003, 10:11 AM   #20
anotherB4
Member#: 6120
BE5B AVOed B4-RSK
Sorta White
The 6 slotter is a totally new box, no relationship to the 5 except that it is a Subaru.
And flex is not unheard of in the 5sp, there is a company that makes bands to fight this IIRC.
anotherB4 is offline   Reply With Quote
Old 10-17-2003, 10:59 AM   #21
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
anotherB4 - Any solid lead as to where to purchase or at least look up a price for a case brace for the 5spd?
Old 10-17-2003, 11:15 AM   #22
anotherB4
Member#: 6120
BE5B AVOed B4-RSK
Sorta White
I am gonna have to say no I am sorry, it has been some years since I was looking at that sort of stuff... <showing my age >
I think it was an Australian company... I've no idea if they are any good or not, HTH in some small way. Perhaps AVO will know (they also do dog boxes etc for Subies).
Old 10-17-2003, 11:17 AM   #23
etam
Member#: 439
www
the link is Japan auction page.. they have a lot of transmission for bid with pictures.. 6speed, bg5, ra etc... if you can't seen them.. I can download and host it somewhere.
Old 10-17-2003, 11:28 AM   #24
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
I could see them I just couldn't distinguish what was what.
Thanks Guys.
Brad
Old 10-17-2003, 11:36 AM   #25
etam
Member#: 439
www
then you need this translation page: http://world.altavista.com/
or take a guess with some letters
ver1 gc8 ra: http://page2.auctions.yahoo.co.jp/jp/auction/b43701005
gdb 6speed: http://page2.auctions.yahoo.co.jp/jp/auction/b43720212
bg5 gt:
http://page2.auctions.yahoo.co.jp/jp/auction/b40036516
Actually, can someone give me a transmission 101 with this picture (in here or new thread) ?
where is 1st, 5th? reverse? etc..
http://img139.ac.yahoo.co.jp/users/6...03p1010028.jpg
WTB: 04/05 Forester turbo 5spd trans darkmist2k1 Private 'Wanted' Classifieds 4 06-16-2007 01:06 AM
Possibly FS: 1993 Subaru Legacy Turbo 5spd MattDell Private Vehicle 'For Sale' Classifieds 3 06-06-2007 08:45 PM
FS: 92-94 Legacy SS 5spd trans subarurabbit NESIC Private Classifieds 6 11-08-2006 11:45 AM
WTB: 91-94 Legacy Turbo 5spd Tranny fishheadback Private 'Wanted' Classifieds 1 09-14-2005 01:38 AM
Needed: Pictures of a WRX, GC8 RS, and Turbo Legacy trans MY99 2.5GT Transmission (AT/MT) & Driveline 4 10-17-2003 04:15 PM
