Old 10-15-2003, 10:21 AM   #1
gothamz_hero
Member#: 45293
2005 Baja
Obsidian Black
Question Impreza Brighton gauge help
I couldn't find anything on the 'net to help me, so hopefully the knowledgable folks who frequent this message board can. I have a Brighton, which as I'm sure you all know is the barest of the bare bones subarus for its time. It's a 1997, and it has no tachometer, which isn't really that big of a deal, but I'd like to install one. The tachometer I bought has 4 leads: Pos, Neg, Input, and one for a light. I've been all over under the hood, and I've had the gauge pod out looking for the wire to use for the signal and I havn't had any luck. I know it's a solid green wire on the later subby's, but mine has no such wire. Perhaps there is no lead for the tachometer, but behind that guage pod are all kinds of wires not connected to anything, so I'm sure it's there somewhere. Thanks in advance for any help you guys can offer!!
gothamz_hero is offline   Reply With Quote
Old 10-15-2003, 10:55 AM   #2
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Not sure if this helps, but there's a wiring diagram for the ECU pinout of my1997 Impreza 2.2 L engine at:
http://www.northursalia.com/index1.html
perhaps you can tap the engine speed output off the ECU. There are wiring diagrams for other model years too, but I'm not sure if any of them are compatible with your Brighton.
satrya is offline   Reply With Quote
Old 10-29-2003, 02:53 AM   #3
Subosche22
Member#: 20398
03 Evolution 8
Tarmac Black
I to have a Brighton and you can either wire your input signal wire to the back of the printed circuit board or even go to the ECU Pin location 64 i Believe its a red wire but mine's a 96 and they may have changed the wire color's. If this doesn't help or you have any other questions let me know
Mitch
PS What are your future plans for the Suby?
Subosche22 is offline   Reply With Quote
Old 10-29-2003, 08:02 AM   #4
avk
Member#: 17252
'06 WX8
59E
On the '97 Brighton cluster, are there mounting holes for an OE tach. on the circuit board? If there are, you can trace the conductors to the connector slots on the sides and see if the signal wire is in the harness. The tach. connections should be for power, ground and ECU signal. The first two, at least, are easy to spot. On a '95, the tach. signal is at the 5th pin from the top on the right side of the board, looking from the back, and the wire is solid red.
avk is offline   Reply With Quote
Old 10-29-2003, 03:46 PM   #5
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
PM RSimport. I know he did this with his Brighton. I believe that he just put in a normal cluster with the tach.
Brent
scoobyimprza is offline   Reply With Quote
Old 10-30-2003, 08:45 AM   #6
RSimport
Member#: 24718
05 impreza RS
white
that would be correct all you have to do is put the tach in and it works there is no wiring required just a few screw turns and you should have it working. If you need any help just let me know.
Chris
RSimport is offline   Reply With Quote
Old 02-13-2015, 07:26 PM   #7
gothamz_hero
Member#: 45293
2005 Baja
Obsidian Black
I was a jerk face 11 years ago and never thanked you guys or let you know how things went. Bad Me!!
At any rate. I was able to find the correct wire to tap into on the ECU harness, and the little tachometer worked great.
I've since sold the car, to help accommodate my family. I miss it though, no more impreza coupes, and I'm not too impressed with the current state of the BRZ.
I still have my Baja Turbo though, and it's going to be the keeper.
You all have my thanks, much belated. Enjoy your days!
Sent from my SHIELD Tablet using NASIOC mobile app
Old 02-15-2015, 04:38 PM   #8
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Glad it worked out.
Not impressed with the BRZ eh? In what way?
Old 02-15-2015, 05:05 PM   #9
gothamz_hero
Member#: 45293
2005 Baja
Obsidian Black
I think BRZ has a ton going for it in terms of style and handling, and I bet its fun to drive.
Not impressed was a poor choice of words, i think disappointed is more appropriate now that i give it more thought.
If they had the rocket option I'd be more interested; fingers crossed for an STI version
Old 02-16-2015, 11:22 AM   #10
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
But the BRZ's premise wasn't about raw power, rather balance, no?
You can always modify the engine if you want more power.
Old 02-18-2015, 10:05 PM   #11
gothamz_hero
Member#: 45293
2005 Baja
Obsidian Black
Admittedly, self inflicted disappointment is responsible for my lack of enthusiasm. When I first saw the pictures, my eye balls were the size of dinner plates, then I got to reading specs and felt a little let down. My brain prematurely related its appearance to hot rod shenanigans. I was expecting it to be more analogous to a charger/challenger situation. Sporty sedan with an even sportier coupe in the lineup.
On its own merits, without preconceived ideas, I bet it's a pleasure to own and drive though.
Gauging Interest: Trade my '99 Impreza 2.5RS for your impreza Brighton Danny Boy NESIC Private Classifieds 20 11-14-2007 09:19 AM
96 subaru impreza brighton help BenjiG Service & Maintenance 1 02-15-2005 03:20 PM
Impreza Brighton Wagon Sighting in RMD 5 Zigen Vancouver Impreza Club Forum -- VIC 0 11-24-2001 11:26 PM
1996 Impreza Brighton Turbo Questions KarZoned Normally Aspirated with bolt-on Forced Induction Powertrain 7 08-31-2001 05:00 AM
which to buy? Impreza Brighton or Outback Sport? Garvinator Canada Region Forum 12 12-20-2000 07:35 PM
