Old 10-15-2003, 10:23 AM   #1
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
Default High pitched wistle at high RPM when under boost.
Today after about 6k when under boost say on a WOT 3rd gear pull I head a high pitched wistle above the normal wine of the turbo. Boost is not changing when it happens and I had already been at 1.19-1.2 bar since about 4k. The wistle when it comes on is not instantanios it starts to come on at 6k and gradually gets louder on the way to redline. I don't really hear it in 1nd and 2nd, but the motor goes threw the RPMs pretty quick there. But WOT in 3rd and 4th at 6k and above it is there.
I checked for leaks, and every thing seems good. Maybe it is just the turbo, I have a TuboXS shorty so I get the whoosh of the air coming in as well as the normal turbo wine, maybe it has always been there and I just never noticed. But after a year and a half you would think that I would have noticed it before.
roybfr is offline   Reply With Quote
Old 10-15-2003, 11:14 AM   #2
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Default Re: High pitched wistle at high RPM when under boost.
Check for cracked blades in the compressor.
But it does sound like a hose leak. If it were a "psst psst psst" sound that would indicate an up-pipe leak. but a solid higher pitched whine is typical of a hose leak, or a cracked compressor wheel.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 10-15-2003, 12:22 PM   #3
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
I will do that. The hose on my V2 TXS top mount is a little short and it on the compressor outlet just far enough to clamp on so it may be there. The other thought was the blow off valve. I had it off about a month a go to install a GFB one that did not fit. To use the GFB I had to reuse the recirculation concetor from the stock one. When I put it back on the stock valve I may not have gotten one of the screws tight enough. It looks to be screwed down tight but at high boost/high rpm when I am moving a lot of air it maybe there is enought pressure for some to start to slip out.
How would the compressor wheel of gotten cracked? Heat?
Well I guess I will take the I/C off this weekend and check it all out. Ugg hate taking that I/C off the core weights a ton, my back hurts just thinking about it.
08 2.5i AT pinging at low RPM when warm out... normal? SportshiftedSSM508 Normally Aspirated Powertrain 79 07-28-2013 01:45 PM
High Pitched Whistle at 3K RPM FD777 Newbies & FAQs 23 08-16-2005 07:20 PM
High pitched wistle?? cronic Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-20-2004 02:09 PM
Rough idle and high-pitched whine at high RPMs fastenova Legacy Forum 10 11-21-2003 02:50 PM
High Pitched Whistling At 70-75 MPH Cruising speed BryanD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-25-2001 03:14 PM
