Old 10-15-2003, 10:23 AM   #1
bluestone
Member#: 36583
2004 WRX sedan
Default DRL and HID on a 2004 WRX
These questions are 2004 specific.
I read all the threads on disabling DRL on a 2002-03, but still can't figure it out. Is the unit moved in 2004? They said you should be able to see it behind the glovebox. Do I need to take apart the glovebox to be able to see it? Comparing to the pics I've seen, I see two plugs up front but don't see the DRL unit behind it. I see the small metal box in the engine bay, and it turns off (but still hear a click behind glovebox) when I unplug that but someone said that's the wrong one to unplug for HIDs.
Second question, this is stupid, but I can't figure out how to get the H1 bulbs out. It's not the twist and pull like regular bulbs, how do you get that metal bracket off? I've tried to bend it every which way but there's not much room. Thanks.
bluestone is offline   Reply With Quote
Old 10-15-2003, 03:24 PM   #2
jin psu
Member#: 35547
2004 WRB WRX
Yes you do need to remove the glove box to get to the DRL unit. There are a ton of screws but its fairly easy to find them all. Once you have the glove box off the DRL plug will be on the right side next to the door. It says DRL Unit (or something to that affect) on the top of it. Just undo the connector and put the glove box back on.
As for your second question, I have no idea... haven't tried to do that yet.
Justin.
jin psu is offline   Reply With Quote
Old 10-15-2003, 04:24 PM   #3
Jeff_DML
Member#: 32018
2008 M3 Sedan
Interlagos Blue
why do you guys disable them? I dont want them but I also dont care that I have them.
just wondering
thx
Jeff_DML is offline   Reply With Quote
Old 10-15-2003, 04:56 PM   #4
FryRice
Member#: 38402
2004 WRX~vf34 SOLD
EVO MR
I did it the reason i did it is because i can turn it off and on when i want to and i got hid which it's kinda annoy to other people
FryRice is offline   Reply With Quote
Old 10-16-2003, 01:06 AM   #5
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Since the OEM DRLs are the normal headlights run at reduced power (the module under the hood is a resistor pack, the stuff behind the glove box handles switching), and HIDs won't turn on properly with reduced power, installing HIDs run off the OEM wiring causes all kinds of problems unless the DRL function is properly disabled.
Old 10-16-2003, 10:49 AM   #6
bluestone
Member#: 36583
2004 WRX sedan
thanks. i'll take apart the glovebox when i have a couple minutes.
now can anyone tell me how to get those bulbs out?
or anyone have those pdf service manuals... i could use them in the future
Old 10-16-2003, 05:40 PM   #7
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Wink
It's very interesting what I found after reading the wiring diagram for a MY00 (and I don't believe they would change all that much for the later models)
Unplugging the resistor do disable DRL, and the only reason why HID would still turn on after the resistor is pulled, is because the control circuit for the relay is tied directly to ground instead of thru the low beam wire. Headlights (at least in MY00) uses common switched power, so the low beam wire on the plug actually leads to a ground. The bulk of the logic is after the low beam wire - they control whether the low beam should go thru the DRL ground (with the resistor) or thru the ground controlled by combination switch on the steering column.
kgb is offline   Reply With Quote
Old 10-21-2003, 10:24 AM   #8
kbcr3
Member#: 44170
2010 Forester XT
05 and 09 honda ruckus
whoa, wait a sec. if you want to disable the DRL for the 2004 all you have to do is open the hood and pull the plug on the DRL unit. Its pretty easy to access. I did it in the day light in like 45 seconds. you just need to have some reasonably flexible to get in there. some people taped the plug once removed, I just tucked it behind some other wiring and wrapped it in electrical tape. total project time = 3 minutes
kbcr3 is offline   Reply With Quote
Old 10-21-2003, 10:34 AM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Removing the dropping resistor under the hood is fine to disable DRLs with stock lights. However if the module is left in place, it will still switch the common headlight power on for DRL operation. If HIDs are installed and use the existing power but have their own ground (which is the proper way to wire them), then they will come on when the DRLs are activated. This is why the control module has to be completely disconnected with HIDs.
Old 10-21-2003, 12:42 PM   #10
kbcr3
Member#: 44170
2010 Forester XT
Default in mulder we trust
mulder,
so you are sayig that just unpluggin the module under the hood is not an effective way to disable the DRL? And you are saying that the correct way is to remove the glovebox and unplug that module? Tell me if this is correct because I am hopefully getting a HID system soon and don't want to burn the puppies out in like a week.
Old 10-21-2003, 01:12 PM   #11
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yes, that's what I'm saying if you are installing HIDs. It's not that hard to get to the module, in fact if you know what you're looking at under there you can lie on your back and reach up to the connector, and unplug it without pulling the glovebox. I've done it a few times.
But if you prefer to remove the glovebox it's not a big deal, it takes about five minutes. Just a bunch of screws (9 IIRC).
Old 10-21-2003, 03:22 PM   #12
kbcr3
Member#: 44170
2010 Forester XT
I just ran out to my car and unplugged it. I plugged back in the module under the hood. It was too easy to get to that plug underneath the glovebox. I wasn't positive if I was looking at the correct plug, so I popped off the plastic screw on the side of the glovebox, near the door, and saw the correct module. Thanks.
In Mulder We Trust
Old 02-18-2008, 11:16 AM   #13
hoffmanEstates
Member#: 122043
04 wagonier
psm
Smile
i done HIDS on my 04 wagon 6K and i found 2 relays blue and black i noticed the blue will turn off the drl but also head lites in the process i have hard time finding black drl box. the H1 came out easy the metal clasp has to push in and down wards. i noticed that when i move the bulb in the socket it adj. light up or down so i dremeled the metal socket,comes out with 2 philips screws one on each side, so i have the bulbs pointing upwards so lite projects down wards with out having to do headlite adjustemnt. took me 2 hours for everythings i baught a MAXX hid kit has 1 year warrenty
hoffmanEstates is offline   Reply With Quote
Old 04-04-2008, 03:00 PM   #14
SideWay
Member#: 148497
04 Stage II WRX
Java Black Pearl
So the proper way is to pull the DRL module from behind the glove box, AND pull the resistor pack ?
Would it be wrong to do both ? and it is the small silver box near the boost control solenoid with a CAUTION HIGH TEMP warning on it ?
SideWay is offline   Reply With Quote
Old 04-04-2008, 03:19 PM   #15
mikeythejew
Member#: 141672
just wondering
thx
General Motors is good at doing studies on everything auto related. Over 12k miles, your car will burn a few gallons of gas just to power DRL's http://www.outsidethebeltway.com/arc...unning_lights/
I disconnect them because of global warming!
mikeythejew is offline   Reply With Quote
Old 04-04-2008, 04:09 PM   #16
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
i really find that hard to believe.. when the car is running, the alternator is always spinning.. its not like it takes extra power from the motor JUST to keep the lights on
maybe im wrong, i dont know... this theory just seems silly to me
jdubya301 is offline   Reply With Quote
2004 STI HID SWAP to 2004 WRX Mfinaldi Electrical & Lighting 35 11-13-2009 06:24 AM
HIDS for a 2004 wrx 04WRBWRX Electrical & Lighting 1 10-12-2007 10:45 PM
Can a 2003 utec be upgraded and put on a 2004 wrx? disque71 Engine Management & Tuning 1 09-25-2005 10:55 PM
HID kit install on a 2004 wrx kbcr3 Electrical & Lighting 11 04-25-2005 01:33 PM
Dyno Results and Implications on CA 2004 WRX ECU Programming adg016 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-13-2004 11:15 PM
