Old 10-15-2003, 12:16 PM   #1
jacksonww
Member#: 5181
1997 Legacy GT
Default Loud Lifters
I had my head gaskets replaced last week along with may other things. Car runs great now!!
Problem - The thing sounds like a semi-truck. The lifters are loud while running at speed or at idle.
Any idea what may be causing this? The mechanic did adjust everything including the lifters to spec.
Thanks
jacksonww is offline   Reply With Quote
Old 10-15-2003, 01:20 PM   #2
outback2.5HO
Member#: 15135
95 GF WRX
Sounds like the valves are out of adjustment.
We're the valves reshimmed? Could also be low oil level, but doubt it.. Has your tech worked on 2.5s before?
outback2.5HO is offline   Reply With Quote
Old 10-15-2003, 02:23 PM   #3
jacksonww
Member#: 5181
1997 Legacy GT
Nope, the valves were not reshimmed, only adjusted to spec.
Oil is fine.
Should I worry?
Other than noise everything seems top noch. I do have 100k on the car.
Thanks again,
Jack
Old 10-15-2003, 02:34 PM   #4
outback2.5HO
Member#: 15135
95 GF WRX
They can't be adjusted to spec without reshimming (DOHC?)...
Old 10-15-2003, 03:01 PM   #5
jacksonww
Member#: 5181
1997 Legacy GT
Yup, DOHC.
You say they can't be adjusted without reshimming?
What I saw is the mechanic adjusting each one almost like to you set the gap on a spark plug. Is this reshimming? Pulling it out and putting it back in, adjusting the gap until it met the required specs.
Old 10-15-2003, 03:58 PM   #6
outback2.5HO
Member#: 15135
95 GF WRX
Question
Was he checking clearances (with a feeler guage), taking out little silver discs (shims) and sanding them, replacing them or moving them to different spots? If so then, it should be in spec. Were the heads already on the engine when he was adjusting?
Old 10-15-2003, 05:29 PM   #7
jacksonww
Member#: 5181
1997 Legacy GT
Was he checking clearances (with a feeler guage), taking out little silver discs (shims) and sanding them, replacing them or moving them to different spots? Yes
Were the heads already on the engine when he was adjusting? Yes
Old 10-15-2003, 05:33 PM   #8
jacksonww
Member#: 5181
1997 Legacy GT
Can this be corrected without pulling the motor? It seems to only be loud on the drivers side.
Thanks
Old 10-15-2003, 07:10 PM   #9
outback2.5HO
Member#: 15135
95 GF WRX
You can do it in the car, but it's a little more work. If your mechanic guarantees his work, you should have him fix it. At least run it by him and see what he thinks.
Old 10-15-2003, 08:50 PM   #10
jacksonww
Member#: 5181
1997 Legacy GT
When I talked to my mechanic he stated it should be fine. I dissagre however.
What exactly am I asking for him to correct? Re-adjusting the valves? How much more do you think this will cost?
Thanks for all of your help.
Jack
hydraulic lifters or solid lifters??? keihacker Legacy Forum 0 02-11-2008 07:33 PM
Pulled p0303 and p0304 codes plus loud lifter tick Big_Hitter Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-20-2005 08:05 AM
loud but not too loud exhaust? 04subaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-27-2003 06:15 PM
How loud is too loud?.. Hazdaz New England Impreza Club Forum -- NESIC 16 02-21-2002 03:32 PM
You want loud?, I got loud!! IMPREZIV Tri-State Area Forum 23 11-29-2001 01:04 AM
