Old 10-15-2003, 01:54 PM   #1
Darkelf_99
Member#: 29204
Default Pulled over for having HID?
To all WRX owners with HID mods, i wanted to ask:
- Have you every been pulled over for having HIDs?
- What do u do in that situation?
- What is the worst that can happen?
I ask because i am considering getting lhd STI projectors with an HID kit, but i dont want to attract attention from cops.
Thanks
Darkelf_99 is offline   Reply With Quote
Old 10-15-2003, 02:51 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Default Re: Pulled over for having HID?
Thanks
Then don't.
Old 10-15-2003, 02:52 PM   #3
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
I've had my HID's for about nine months now and never been pulled over. I have been behind cop cars drove past them head-on and nothing. Could be the area I live in as we don't really have that much trouble with modified cars compared to some of the bigger cities (i.e. LA, NY, Atlanta, Orlando, Miami, etc...). If you do get pulled over, they'll give you a warning and tell you to get them off your car. If you don't and they catch you again, then you'll get a fine as to my understanding.
I've also got projectors and the spread of the light is less-glaring than aftermarket HIDs in reflectors.
Hank3 is offline   Reply With Quote
Old 10-15-2003, 02:56 PM   #4
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
It's up to the discretion of the officer. If you're violating the law, prepare to be held responsible (i.e. ticket, fine, etc).
Kean is offline   Reply With Quote
Old 10-15-2003, 03:44 PM   #5
Darkelf_99
Member#: 29204
So would you just tell the police officer that you were not aware that HIDs were illegal? Is it standard procedure to first warn, then fine?
Just as a side note, i was planning to get the HID kit in the STI projectors, so maybe that's better.
Old 10-15-2003, 04:04 PM   #6
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
Heh, good luck with that strategy. Feigning ignorance may not help you, and even if you truly didn't know, that doesn't give you a free pass to violate the law.
Regarding the warning vs. fine...I would think that largely depends on the particular officer's mood that day. I have to imagine that being pulled over solely for having HIDs is not terribly likely...they might write you up after having pulled you over for a moving violation, or suspecting you of having illegal tint, however. The officer would also have to be quite knowledgeable about which cars do and do not come with HIDs from the factory these days, and correctly identify yours as aftermarket.
Joel
Zola is offline   Reply With Quote
Old 10-15-2003, 04:09 PM   #7
Kean
Member#: 25187
'08 Foz Prem TGM
Ignorance of the law is no excuse in the eyes of some law enforcement. It really depends on the officer. The only thing I'm pointing out is that you should be prepared to pay the price if you do happen to get popped. Check your local vehicle code so you'll know what to expect. Also, I would hold on to your stock headlamps just in case.
.....who knows....you may not ever have a problem. I drove around in my Chevy p/u for 11 years without a front plate (was even pulled over twice). I was never warned or given a ticket for it (it's illegal to not have one in CA). I haven't had one on my WRX either since I bought it (a year ago). .....so far so good.
- Kean
Old 10-15-2003, 04:27 PM   #8
dowroa
Member#: 17498
No More Subarus :(
Only a truck, for now. ;)
Question what?
So....
I was never under the impression that the EDM STi HID lights were illegal. Where are you sourcing this information from?
I DO know that the JDM RHD lights shoot the beam pattern into oncoming traffic resulting in a lot of flashing from oncoming drivers, but I have never heard of the HIDs breaking any sort or national or local statute.
I say this as I have been researching HIDs for quite a while, and this is going to be one of the very near future mods for my car. If someone does know something, let me know. I was under the impression that the EMD lenses were DOT approved, and hence, no problem.
As long as you are not directly sending light into on-coming traffic (JDM STi HIDs), I dont see a problem.
I bet someone tells me that the EDMs were never offered in HID
- dow
dowroa is offline   Reply With Quote
Old 10-15-2003, 04:37 PM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It's illegal to modify your OEM headlights in any way, including replacing them with factory lights used in non-US models. However the tolerance of local authorities varies and unless they are very strict in your particular area you should not have a problem as long as your lights are LHD, properly aimed, and not excessively blue. It also helps not to drive around with fog, high beam, and driving lights on when they are not needed.
I have Morettes with 4500K HIDs and in over a year with them I have never been flashed, pulled over, ticketed or otherwise bothered about them. I drive around the NYC area regularly.
Go ahead and upgrade your lighting, but as with other mods be prepared to deal with any legal consequences that may come up.
Old 10-15-2003, 05:07 PM   #10
brunetmj
Member#: 8023
2004 2.5 RS
A bigger issue regarding after market lighting is Inspection. I know many people get through inspection without problems but be aware that it can be an issue. Odds of being stopped by police with well aimed lights is remote. Inspection is another matter.
brunetmj is offline   Reply With Quote
Old 10-15-2003, 05:19 PM   #11
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Inspection is part of what I was referring to with regard to local authorities. The other aspect of that is enforcement by PD and whether they will pull you over. It's possible to have to change your lights to get through inspection but never have a problem with them driving around. Or conversely you could get stopped frequently for "improper lights" but pass inspection. A little research should reveal what the situation is in your town and state.
Old 10-15-2003, 05:25 PM   #12
Darkelf_99
Member#: 29204
I see. I guess the worst case scenario is i get fined and keep my stock lights handy...
I plan to buy the EDM STI projectors, is it safe to assume that they are properly aimed for use here?
Also, how bright an HID kit would u guys recommend?
Old 10-15-2003, 05:31 PM   #13
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
EDM lights will have the correct LHD beam pattern, just be sure to aim them properly.
For HIDs stay away from the high color temperature kits, 5000K or under is best for usable light output and minimal glare. Anything higher will be more blue/purple and will tend to attract more unwanted attention.
The NHTSA has officially banned vendors from selling any more aftermarket HID kits so the selection may not be what it once was.
Old 10-15-2003, 06:33 PM   #14
Darkelf_99
Member#: 29204
if they have the correct lhd beam pattern, why is it necessary to also aim them? shouldnt they be aimed in the right direction already?
Old 10-15-2003, 06:38 PM   #15
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
All headlights have to be aimed when they are actually in the car. The beam pattern is set by the reflector or optics in the light assembly, but you still have to point it the right way
Old 10-15-2003, 08:01 PM   #16
Darkelf_99
Member#: 29204
As you can see, i know nothing about car headlights...
so how is this aiming done?
Old 10-15-2003, 08:21 PM   #17
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
Default Re: what?
Well, it's true that the EDM lights have the DOT marking on the lens cover. I can take a picture if you want. However, we have gone round and round on this issue here on the forums in the past, and I have yet to see anything which disproves my belief that DOT and E-code certifications are mutually exclusive. I suppose you could try calling someone at NHTSA, I'm sure they could give you a definitive answer. When you consider that Subaru never sold Imprezas with projectors here in the US, it's bewildering that the lens covers have the DOT marking. The cover has a little etching where the focal point of the low beam is, so it's a different cover than the USDM Impreza.
But at the end of the day, I think what mulder already posted is correct. You can't technically modify your OEM lighting. Whether or not you can get away with it in practice will depend on local law enforcement and/or state inspections.
I always heard that LHD EDM projectors were in fact never offered with HIDs. If you know differently, please share.
Joel
Old 10-15-2003, 08:55 PM   #18
Basshead
Member#: 112
2011 Jetta TDI
i've had my hid's for 6 months now and no pull overs...of course i imagine having eyelids for glare reduction and a 4300k temperature to give the appearance of stock helps...
Basshead is offline   Reply With Quote
Old 10-16-2003, 12:26 AM   #19
Subie2.5RS2003
Member#: 41941
2003 Impreza 2.5RS
Ridge Blue Pearl
okay i have 8000K HIDs, my lights are bright blue, im originally from brooklyn where almost everyone has xenons on their bimmers n benzs, but now im in school in albany AKA hicksville ... when i got pulled over for speeding he said i'm also giving you a ticket for those razzle dazzle lights (his exact words F-in Hick) anyway i got my tickets etc... i went to the police station the next morning with my stock bulbs in, it took me 10 min to swap i said i dont know what he was talkin about these are original subaru lights ... cop said ha ha no problem and signed off my ticket and told me to have a good day ... i got to my parkin light in school and put in my xenons and i was off to sleep
Subie2.5RS2003 is offline   Reply With Quote
Old 10-16-2003, 12:42 AM   #20
MisterWRX
Member#: 44511
The problem with 8000K bluish lights is that you're sacrificing brightness over looks. Especially when it downpours.. oh well... But hey it's your call. =)
MisterWRX is offline   Reply With Quote
Old 10-16-2003, 08:50 AM   #21
Orson
Member#: 25254
2003 WRX wagon
EDM and JDM lights are illegal in the US. Period.
Everyone else in the world uses the sharply defined cut-off pattern. The US sticks with the more diffuse pattern that throws some light overhead. The exception is HID: because they are so much brighter, HID's in the US are required to have EDM-style sharp cut-off pattern. (There is a picture of this in a Consumer Reports article a few months ago - I wish I had scanned it.)
Strictly speaking, any light not approved by DOT is illegal for use on US public roads, but if you get EDM lights with HID and add the levelling motor function, you are abiding by the spirit of the DOT requirements.
If you want to get a head-ache reading about this, go here:
http://lighting.mbz.org/nhtsa/NHTSA.html
Orson is offline   Reply With Quote
Old 10-16-2003, 12:06 PM   #22
Kean
Member#: 25187
'08 Foz Prem TGM
Default Re: what?
So....
- dow
Sorry for the delay in my response. Actually......it looks like the others pretty much covered your questions.
Here in CA, there are no "black & white" laws against aftermarket lighting that I could find. However, there are plenty of laws that can be "used" against you (glare, tampering, etc) if you do use lighting other than what is supplied by the factory. These laws give broad authority.
I was aware the EDM's had a DOT stamp on the housing, but I heard that it didn't necessarily mean the whole assembly was DOT approved. Some vendors even point this out. Obviously, having the stamp could only help if you run into problems with the authorities. However, depending on your local laws (and the knowledge of the officer), you could end up getting ticketed anyhow. This is why I suggested he look up the local VC for violations he may be committing by running these. In some cases this can be a very grey area.
- Kean
Old 10-16-2003, 12:46 PM   #23
Darkelf_99
Member#: 29204
If you get ticketed, are u also required to replace your headlights with the stock lights? Or can u simply pay the ticket and take your chances of getting another ticket in the future (if u get pulled over again)?
Old 10-16-2003, 12:53 PM   #24
Kean
Member#: 25187
'08 Foz Prem TGM
I would imagine you would be required to remove the "illegal" component and replace it with something legal (i.e. factory part).
Old 10-16-2003, 04:08 PM   #25
Scooby Blue
Member#: 12112
MY00 RS
Sometimes yes and sometimes no. Depends on where you live. In socal, I have gotten fix-it tickets for front tint, and there is a box that says "correctable" or "non-correctable". I have had times were I just paid the fine and went on my way. While other times I had to pay the fine and get the front tint removed. IIRC If the officer marks "non-correctable" I had to do both. (remove and pay)
I guess with these grey areas are really hit and miss sometimes. I just say don't draw extra attention and they won't bother you.
And you can get pulled over again for the same infractions if you continue to have them. I recieved 4 fix-its in 5 years for my front tint. Here is the thing though....the fine increases each time. Started @$30 last one was $140.
Scooby Blue is offline   Reply With Quote
anyone been pulled over for having sylvania silverstar turn signals? jdubya301 General Community 85 10-24-2008 03:44 AM
Have you ever been pulled over for driving a modifed car? MadDogSTi General Community 67 05-29-2008 07:23 PM
Lowest MPH over the limit you were pulled over for? Dragicon Off-Topic 70 08-01-2006 10:50 PM
Got pulled over for NAWs. I DONT HAVE NAWS MikalsWRX Off-Topic 90 12-14-2004 03:01 PM
Pulled over for having a HKS Carbon Ti Azjon Bay Area Impreza Club Forum -- BAIC 21 10-22-2003 01:24 AM
