#1 |
Member#: 42976
SCIC
Vehicle:04' Subie Econobox Rocket |
ADDICT
#2 |
Member#: 19697
Vehicle:2008 WRX STi Aspen White |
Looks good, and glad your happy! w00t
#3 |
Member#: 42594
Vehicle:04 STI black on Black wheels |
wow, 260whp on 91 octane. thats pretty damn good!! so since im on 93 octane, i should be a tab higher right all??
#4 | |
Member#: 42976
SCIC
wrx what.........thanks ADDICT |
#5 |
Member#: 8343
Vehicle:2006 Impreza WRX 1x PS F250 |
Could be higher could be lower. The kind of dyno they are using is going to make it vary wildly. I would say this dyno is probably a bit on the optimistic side. You can't compare results from different dynos at all. I thought that one side was torque at first, do you have a graph of your torque as well?
#6 | |
Member#: 31624
Vehicle:02 WRX White uppipe, turbo-back, MBC |
I question the torque? You say at the crank? Not the wheel? Why would they give you wheel hp and crank torque?I also have to go on record saying, I don't like XS Engineering charts. Why don't they show torque on there? And why do they show M.A.P. kPa? And why don't they have each side of the chart on the same scale? That just drives me batty! ![]() |
#7 |
Member#: 2060
BAIC
Vehicle:00 2.5RS Coupe 01 black boxster hardtop |
260ish HP Wheel & 280ish torque at the crank? huh?
#8 |
Vendor
Member#: 3600
It's a little high. I got 248 bone stock and 250 whp with removed resonator box. I was hittting 14.8 psi.
#9 |
Member#: 8785
SWIC
Vehicle:02 c_turner@ix. netcom.com |
Just to confirm. The DTS Dyno is the highest reading dyno of them all. That does not mean the dyno is a bad dyno.... Just for comparison purposes it reads higher then others.
Thanks Clark |
#10 | |||
Member#: 42976
SCIC
The fact is, dyno # from different brand dyno just can't be compare. My purpose is just so I know how much power I gain after I do all the mods, as long as I stay with one dyno, I am good.ADDICT |
#11 |
Vendor
Member#: 3600
I have a Dynapack 5000 dyno. Our new software reads a bit lower than Turbo XS's Dynapack 4000.
#12 | |
Member#: 42976
SCIC
I always think Dynapack will read the highest since it is measuring power at the hub, it doesn't include the power lost from the weight of the wheels and tires. But there are so many factor involved ADDICT |
#13 |
Member#: 10334
Vehicle:91 RX7 LSx swap '06 Passat 3.6 4motion |
Throw it on a dyno dynamics
Pull around 220whp and be elated. ![]() |
#14 |
Member#: 11617
Errr am I missing something?? I see no dyno chart....
-Jason |
#15 |
Member#: 19697
their was a chart
#16 |
Member#: 13095
