Old 10-15-2003, 04:01 PM   #1
85258
Member#: 45296
Default Sticky Throttle/Throttle Body Cleaning - Warrenty?
My '00 Legacy Gt was having a problem when cold where the RPM would not decrease when the clutch was engaged. It would stay the same of increase slightly for a few seconds.
The dealer diagnoised the problem as a sticking throttle plate and cleaned the throttle body. They claim that there was excessive oil from the K&N filter that was installed (previous owner) that was causing the sticking.
Anyone else have a sticky throttle body not related to K&N? I find it hard to swallow that K&N oil can be viscous enough at 10 degree C to cause my throttle to stick.
85258 is offline   Reply With Quote
Old 10-15-2003, 06:18 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
the k&n probably had little to do with the sticking throttle body.
Throttle bodys do get carboned up and can stick. Some companys have telfon coated TBs to prevent this, Subaru does not.
Jay
Old 10-15-2003, 06:50 PM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Jay
The early legacy TB's had a coating. I don't know exactly what the coating consisted of, but it helped seal the TB, as well as "supposedly prevent carbon from building up"
pics and more info
http://forums.nasioc.com/forums/show...postid=2762206
Legacy777 is offline   Reply With Quote
Old 10-16-2003, 03:02 AM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
Jay
what he said
a can of carb cleaner and a plastic wheel brush(think of it as a giant pipe cleaner) and you can clean it yourself. Not many manufacturers use the Teflon any longer....think of it as my future career
Also on a vehicle with an EGR valve the effect is even worse.
Jeremy
Old 10-17-2003, 12:54 AM   #5
CharT
Member#: 36117
2003 WRX Wagon
Just a note, make sure to use throttle body cleaner and not just carb cleaner. Some carb cleaners can damage the MAF or other electronics. Make sure the cleaner you use says it's for throttle bodies or fuel injected vehicles.
CharT is offline   Reply With Quote
Old 10-17-2003, 04:45 AM   #6
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
no MAF on an RS...and most carb cleaners now are thorottle body cleaners they just use a different colvent now.
Jeremy
Old 10-17-2003, 08:26 AM   #7
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Default Clean Throttle Body
I don't know if the previous owner had cleaned the throttle body on my car, but at 90K mine was remarkably clean. I still opened up the butterfly plate, I think that's what you call it, and shot some into the intake. Like I said, I didn't notice any difference after the cleaning b/c it was clean to start with.
-Charles-
ImprezaVA is offline   Reply With Quote
Old 10-17-2003, 08:45 AM   #8
orndog
Member#: 34670
2013 No gears!
Saltine American
GM trucks had this problem from the factory. Their general rule was to clean it once under warranty, then make you pay
My Focus had this problem, so I just cleaned it myself as it has a Volant intake and I reoiled the filter once at some point and figured the dealer woul blame it.
orndog is offline   Reply With Quote
Throttle Body Cleaning? Can Do? snvin Off-Topic 27 05-15-2008 03:31 PM
Throttle hesitation after cleaning air filter tarbo Service & Maintenance 11 08-16-2007 01:55 AM
Throttle body cleaning Dangerdave Service & Maintenance 6 03-09-2006 12:12 PM
Cleaning of throttle body - Warrenty? 85258 Legacy Forum 5 10-15-2003 05:21 PM
Anyone ever clean their Throttle Body?? Max Umbarger General Forum Archive 6 01-21-2001 03:40 PM
