Old 10-15-2003, 07:00 PM   #1
pag_21083
Member#: 40765
2003 Impreza WRX blk
308.5 awhp
Default low voltage during idle?
I have Morette head and tail lights and about 2000w of stereo equipment. I recently installed the apexi S-AFC II, AVC-R , and Turbo Timer. When the WRX idles the TTs voltage meter reads around 11.9-12.5 which is very low. I have a 5 farad cap for the stereo but i think that with the addition of all the aftermarket lighting/electronics my battery may be overtasked due to the sock alternator. I am in search of a higher output alternator, I would really appericate either a link to buy one or a manufacturer/part #. I have seen annodized ones before but never for the 03 WRX, a blue one would be cool and it would match my engine bay. thanks
pag_21083 is offline   Reply With Quote
Old 10-15-2003, 07:07 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The WRX alternator is rated at 75 amps which is less than the 90 rating of the RS and other Subaru alternators. Unfortunately the cases are not the same so they're not interchangeable.
The output does become marginal at idle and with a heavy enough load the alternator will max out and the battery will begin to discharge.
At the very least replace your battery with an Optima which will tolerate the load much better than the stock one.
As for upgrading the alternator there have been some discussions on it, but no registered vendors have yet stepped forward to offer this service.
As for the Morette lights there is no reason they should increase the drain on the electrical system unless you have replaced the bulbs with higher than stock wattage ones, or you use the high beams all the time (which in the Morettes also keeps the lows on).
low vacuum at idle, low boost; HELP! Deuce Cam Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 08-08-2009 11:14 PM
UTEC: MAF voltage at idle and @ 2k rpms HorsepowerFreaks Engine Management & Tuning 2 02-08-2006 06:16 PM
MAF voltage at idle? TexRex2002 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-14-2003 11:16 PM
Why Limp Mode during IDLE? fc3swrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-14-2003 10:49 PM
MY99 RS overheating and dying during idle, blue and white smoke Cusco Service & Maintenance 6 04-15-2003 01:39 AM
