Old 10-15-2003, 07:33 PM   #1
legacy3kgt
Member#: 44026
1991 Turbo Legacy
Unhappy Turn signals not working
I have a 91 legacy and my turn signals won't work, however the hazard lights do work. any ideas?
(indicator lights don't turn on or anything)
legacy3kgt is offline   Reply With Quote
Old 10-15-2003, 08:36 PM   #2
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
you check the fuse?
subiekid is offline   Reply With Quote
Old 10-15-2003, 08:56 PM   #3
fastenova
Member#: 38829
Not your usual 1997
Legacy GT
Are the turn signals and the hazards on the same relay? IIRC, they have separate relays and fuses... You might want to check the relay as well if the fuse is good. Also, it is possible the multifunction switch on the steering column is bad. You could check with a multimeter at the fuse when you turn either signal on to make sure it's working.
Good luck.
-A
fastenova is offline   Reply With Quote
Old 10-15-2003, 09:13 PM   #4
subiekid
Member#: 25516
two switches to check. most likely its the hazard light button. if that switch is not pluged in no lights will work.
other is the one that alows you to have your lights on with the car off. but it will only affect brake lights and you should still have blinkers with that one.
Old 10-15-2003, 11:32 PM   #5
legacy3kgt
Member#: 44026
1991 Turbo Legacy
thanks
Turn Signals don't work... Hazards work fine, relay? Fuse? LatentWagen Electrical & Lighting 10 04-15-2008 10:40 AM
Turn Signals not working/R1 Rims? MarylandEcstasy Electrical & Lighting 3 01-05-2006 01:02 PM
Turn signal not working chuckles New England Impreza Club Forum -- NESIC 10 04-22-2004 10:04 AM
Turn signals aren't working...02 WRX scotter Electrical & Lighting 4 06-25-2003 12:22 AM
('93-'01) Turn signals aren't working evilwrx Impreza Forum 4 10-19-2001 11:57 AM
