#1 |
Member#: 34631
Vehicle:2008 e92 335i space grey |
My heat shields make my Suby sound like a car less than it is. Has anyone removed thier shields from the manifold back or which ones have you removed? I know it shouldn't be but is there any adverse effect of removing the shields?
#2 |
Member#: 12900
Vehicle:1997 Legacy GT-Turbo Quick Silver Metallic |
When I had my ej25, I had all the heat shields torched off because they were rattling so badly. Just don't park on the grass
#3 |
Member#: 16653
NESIC
Vehicle:2012 Mazda 3 2004 Honda Pilot |
I've cut or ground off at least half the heatshields, because of incessant rattling.
I try not to park on tall grass. ![]() -Brian |
#4 |
Member#: 8124
Vehicle:1998 Old Grey Mule Regacy Rype R |
I don't have my heat shields. They rattled like crap.
#5 |
Member#: 25516
NWIC
Vehicle:1995 Legacy TURBO!!! EJ22T/TEC3 & '12 Civic |
took them off when the did the motor transplant.
#6 |
Member#: 6982
Vehicle:2001 Legover 04 forester xt |
Whats the best way to get rid of them?
#7 |
Member#: 25516
NWIC
muffler shop, they can use an air saw. the bolts will all be rusted and striped.
#8 |
Member#: 4800
TXIC
Vehicle:1990 Legacy & 97 OBS AWD 5MT EJ22T AWIC Swap |
I need to take mine off....they're driving me nuts......
#9 |
Member#: 43493
Vehicle:99 Legacy GT Limit Silver |
was wondering what that noise was - rarely happens so i hadn't gotten around to checking it out yet.. maybe i can tack weld the part that is rattling to something solid..
#10 |
Member#: 30556
Vehicle:2000 Legacy GT (BE) over 250,000 Miles |
my stock header ones were rattling.. all other are fine.. wasn't really concerned because I did replace headers about month later.. now nothing rattles.. there are still all under the body and on the catalityc conv... but there i had to re-do the clamps and replace bolts..
#11 |
Member#: 4800
TXIC
the exhaust guy that did my muffler tried to weld the shield on to the pipe and pretty much just put a nice hole in my mid-pipe.
If the bracket holding it on is rusted, you wouldn't really be able to weld it to the pipe too well. You could try though. |
#12 |
Member#: 45436
Vehicle:1998 Legacy GT Red |
I was able to stop the rattling by clamping the shields down to the pipe with some universal exhaust u-clamps.
#13 | |
Member#: 30556
otherwise it would just put big hole in pipe.. |
#14 |
Member#: 4800
TXIC
he did use a gas welder....but he still put a hole in the pipe.....like I said....I was not impressed with their work......
#15 | |
Member#: 43493
i still have to check out the situation before i decide what to do.. so its the heat shield at the cat? that you guys have been dealing with? |
#16 |
Member#: 30556
kohburn
I'm using stock dual cats and yes.. I still have heat shield on it.. these suckers can get really hot.. much hotter than exhaust pipes... Headers - borla the one i use, nope don't have shield since isn't recommended by mfg. rest of the car i have only heat shield on underbody of the car, not on the pipes... |
#17 |
Member#: 45187
Vehicle:99 Legacy Outback Winestone |
I have heat shield rattles on mine too. Will removing the heat shields not damage the the steering rack rubber boots above the pipe?
#18 | |
Member#: 30556
#19 |
Member#: 45703
NWIC
weeelll... I slapped a metal saw in my skill saw and got under there and made some sparks. it was damn fun. later used the stainless fora few projects.
#20 |
Member#: 45187
Well, I tried the universal U clamps and it did not work for me. Guess I will just remove the shields.
#21 | |
Member#: 30556
Look @ #8 on the picture, kinda C with the wings clamps. |
#22 |
Member#: 32503
TXIC
Vehicle:2011 Tribeca 1995 Legacy Wagon |
I thought my heat shield was rattling too, but upon inspection with the car on a hydraulic lift it was one of the exhaust clips that had broken in 2 and was rattling up against the cat converter. Got it welded it back together, and now it's great. Just thought I'd pass that along...
#23 | |
Member#: 45187
#24 |
Member#: 23337
Vehicle:1997 Legacy GT Sedan Black |
I found that creative use of pipe clamps solved the rattle for me ... for a while. I've got to crawl under there and tighten one of them again.
![]() -- Bill |
#25 |
Member#: 6982
I went under the car and tapped around with a rubber mallet and found an off sounding one. I took it off and it's nice and quite now.
| Thread Tools | |
| Display Modes | |
| Lot of part vf39 injector cf exhaust heat shield cusco heat shield Ect | ppericfe | Tri-State Area Private Classifieds | 14 | 02-28-2009 08:08 AM |
| (NYC)Lot of part vf39 injector cf exhaust heat shield cusco heat shield Ect | ppericfe | Engine/Power/Exhaust | 13 | 01-07-2009 11:27 PM |
| Bad idea to remove exhaust heat shields? | RoadTrippin | Normally Aspirated Powertrain | 6 | 04-27-2008 10:35 PM |
| If I remove an exhaust heat shield, the car will burst into flames TRUE OR FALSE | kaisersouse | General Community | 9 | 10-10-2006 08:41 AM |
| Removal of cat heat shields? | Layman | Normally Aspirated Powertrain | 4 | 01-29-2003 10:54 AM |
