Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 10-17-2003, 10:20 AM   #1
Schleppy
Member#: 15858
SPB
Default To the local's who've done a gauge install: Where is the front oil gallery plug?
I'm finally ready to do my gauge install. I've got a VDO EGT/Oil Pres./Oil Temp. I've got all the senders, and I've got the stainless tube for remotely locating the oil pressure gauge (I'm going to use the oil gallery under the IC for the pressure gauge).
Anyway, I want to install the temp gauge in the front oil gallery that the stock (and useless) oil pressure sender is using. I know many people have installed their senders there, and I was just wondering where exactly the stock pressure sensor is so I can take it out and put my VDO sender in...
Thanks all!
-Sean
Schleppy is offline   Reply With Quote
Old 10-17-2003, 10:44 AM   #2
webkris
Member#: 70
I sold WRX to buy
Dodge Neon Rally Car
Lightbulb
Under the alternator.
Right next to the engine code stamp.
(EJ20 for the WRX)
- Kris
webkris is offline   Reply With Quote
Old 10-17-2003, 10:55 AM   #3
Schleppy
Member#: 15858
SPB
Hmm. What tools can get that bad boy out?
Old 10-17-2003, 11:59 AM   #4
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Hand tools will work, so will air tools . It will be easier if you remove the alternator, but it's something you can take apart with an open ended wrench.
Brian
Old 10-17-2003, 12:17 PM   #5
Schleppy
Member#: 15858
SPB
I think I'll try the hand tools route without removing the alternator. I'm not feeling that adventurous :-)
Thanks all!
Old 10-17-2003, 12:22 PM   #6
subarurabbit
Member#: 4083
2011 OB 3.6R
Sean,
it will be SO much easier removing the alternator.
subarurabbit is offline   Reply With Quote
Old 10-18-2003, 02:12 AM   #7
Schleppy
Member#: 15858
SPB
How does one remove the alternator?
Old 10-18-2003, 03:07 AM   #8
V6TurboTA
Member#: 9090
09 Forester Gump
02WRX->04STi->09Gump
with hand tools... or air tools...
~v6
V6TurboTA is offline   Reply With Quote
Old 10-18-2003, 09:37 AM   #9
Schleppy
Member#: 15858
SPB
Thanks B Which kind of tool are you?
Old 01-12-2006, 09:34 PM   #10
igoeasy
Member#: 5690
02 WRB GDA
Thanks all!
Were you able to pull it off without removing alternator ?
I'm looking to install my Oil Pressure sender as well. And hopefully use the existing plug there.
How difficult is to remove and reinstall alternator btw ? Just a couple bolts , loosen belt, and remember to mark where the tension bolt right ?
igoeasy is offline   Reply With Quote
Old 01-13-2006, 08:10 AM   #11
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
12mm for belt tensioner top and bottom. Remove bottom bolt. Remove top bolt. 12mm to remove 12V+ on top of alternator. One electrical clip on top of alternator. One 12mm bolt ont he left of alternator going horizontal. Don't drop the capture nut on the backside. Alternator is off. Wiggle/shimmy alternator up.. tight fit on the bushings.
FYI... mechanical oil pressure senders work with a T; Electrical needs a T also and needs to be pointed toward the front of the car.
Fitz
Fitz is offline   Reply With Quote
Old 01-14-2006, 02:44 PM   #12
igoeasy
Member#: 5690
02 WRB GDA
thanks for quick reply Fitz as your tips really helped. removing this alternator was cake. I didnt use any T's as I just swapped out the oem sender with a Blitz one.
Old 01-14-2006, 08:33 PM   #13
TunerNetwork
Member#: 65039
04 Subaru WRX
www.TunerNetwork.com
just take your motor out, thats what i did ;-)
TunerNetwork is offline   Reply With Quote
Where is the oil gallery plug under the intercooler? Pic inside Donnie_Doritos Newbies & FAQs 7 07-13-2008 08:47 PM
Oil Gallery Plug - Where to find locally? Subarutex North West Impreza Club Forum -- NWIC 5 07-27-2007 07:11 PM
Wanted: the plug you remove to put in an oil gallery plug North Ursalia New England Impreza Club Forum -- NESIC 15 07-01-2005 02:41 PM
[EGT,OIL]Where is the best place to install the sensors to my gauges in the engine? west Interior & Exterior Modification 2 05-06-2005 09:04 PM
Indiglo gauges installed- where is the "whine" coming from? The_Triton Interior & Exterior Modification 12 10-30-2002 11:46 AM
