Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 10-20-2003, 01:39 PM   #26
Mr. Bungle
Member#: 44091
'07 STi
Obshidian Burakku
I usually fill at around 1/4 tank remaining, and the most miles I have gotten to date is around 190, and that was with a good bit of highway driving. On average I get around 160 miles per fill.
Mr. Bungle is offline   Reply With Quote
Old 10-20-2003, 08:57 PM   #27
BluSuby
Member#: 12154
04 Sti
99 Outback
I'm getting about 20mpg on my daily commute which is 50 miles roundtrip on a hilly and curvy 2 lane highway. I just went on a roadtrip this weekend to VA and got about 22 on PA's crappy I-81. That was driving several times at a crawl and idling in clogged construction areas. On the way home there was less taffic so I could use cruise more. I got 25.5 on that tank. I've never got less than 260 miles per tank. The car is 1 month old and now has 2k miles on it,
Bryan
BluSuby is offline   Reply With Quote
Old 10-20-2003, 10:56 PM   #28
tolnep
Member#: 18602
2005 Moller Skycar
glow in dark purple
Originally posted by redrexx
If you get any more than 20 mpg, you are driving the wrong car.
Welll.... if you go on a long trip, you gonna tac it out the whole way? Now a vette gets around 30 mpg cruising all day above 80 mph.. interstate miles. Nothing wrong with sucking it up at WOT.. but nothing wrong with getting 30mpg on a long trip either....
tolnep is offline   Reply With Quote
Old 10-21-2003, 12:07 AM   #29
limpreza
Member#: 44949
2004 STi
java black
Has anyone else gotten better gas mileage on Shell (93). Today I was driving pretty hard on hilly and curvy backroads and I got 24 mpg. That's higher than I get on Mobil driving like a grandpa.
limpreza is offline   Reply With Quote
Old 10-21-2003, 01:07 AM   #30
filbert
Member#: 39661
2004 WRB WRX STi
07 OBP FXTS
shell has been advertising that their gasses get better mileage... don't know how that works though...
filbert is offline   Reply With Quote
Old 10-21-2003, 01:50 AM   #31
ToddStratton
Member#: 8351
2002 WRX Wagon
I see about 280-300 miles per tank with normal driving. Includes a few good runs through the gears every day it is driven. Even on my current tank with an autocross it'll be over 270. 5500 miles so far.
TRS
ToddStratton is offline   Reply With Quote
Old 10-21-2003, 01:56 AM   #32
ToddStratton
Member#: 8351
2002 WRX Wagon
Different formulations will have different energy content. Ethanol doesn't have the energy content of gasoline, so ethanol blends typically get slightly lower mileage. (1-3 mpg less in my experience).
TRS
Old 10-21-2003, 05:43 PM   #33
Smittys_STi
Member#: 42421
2008 STi
5200 miles here ..
Best - 26 MPG (All Highway)
Worst - 16 MPG (Hard driving city/highway)
Composite for around 20 fill-ups - 20 MPG
Smittys_STi is offline   Reply With Quote
Old 10-22-2003, 11:53 AM   #34
filbert
Member#: 39661
2004 WRB WRX STi
07 OBP FXTS
TRS
so you think that those new shell ads are because shell has started reducing the ethanol in their gasolines?
Old 10-22-2003, 10:19 PM   #35
Fogrider
Member#: 45806
'04 STI WRB
'95 GC8 Rally car, white
best- 25.7 mpg
worst- 18.0 mpg
we'll see what snow tires do to these numbers.
Fogrider is offline   Reply With Quote
Old 10-23-2003, 12:03 AM   #36
Waltsacura
Member#: 813
07 Outback
I have over 4600 miles on mine. range from 13mpg to 23mpg. Boost= lots of fun= lots of gas. Damn I love this car.
Snow should prove interesting, we're supposed to get a ton of snow this year. I'll have to go back home to NY to find some really fun roads.
Gas isn't really that expensive. 100 Octane is only like $4.30 a gallon here, now that's an expensive but really fun treat! Think about everyone else in the world that pays out the ass for gas (although we get crappy oxygenated fuel here near Philly).
Waltsacura is offline   Reply With Quote
Old 10-23-2003, 01:31 PM   #37
Maverick1
Member#: 41856
Default might have a problem....?????
I think I might have a problem with my car. I am only getting 16 miles per gallon all the time. I doesn't matter if it includes a lot of highway.
Is there any way to turn down the amount of fuel being sent to the engine. Any way to make the car more lean??? and thus get more mileage???
I have read that the car comes very very rich from the factory, and that leaning out the engine a little would not hurt it at all. How would I do this???
I think it is silly wasting excess fuel when you don't have to.
Cheers
Maverick1 is offline   Reply With Quote
Old 10-24-2003, 12:44 AM   #38
turbowrx03
Member#: 28866
04 STI
SILVER
Default milage
I'm averaging 275 - 310 per tank - down to low fuel light.
I drive 500 HWY miles weekly, but I jump on it alot. I run 94 Octane for 3 tanks and then drop a tank of 100 in. That is the way I've been driving it from day 1. Synthetic oil....
11158 miles and counting
turbowrx03 is offline   Reply With Quote
Old 10-24-2003, 08:41 PM   #39
Fogrider
Member#: 45806
'04 STI WRB
Maverick1, a couple questions for you...
How did you break your STI in? What tire pressure are you running? (How often do you check? Checking tire pressure is cheap and easy but occasionally overlooked.) Could your alignment be off? What DCCD setting(s) are you running? What shift points are you using? Is your air filter clean? How much throtle pressure do you use when changing velocities? Do you brake late and hard then power out of corners (always) or "coast in, coast out"? How much steering input do you use when traveling a straight course? A 1% steering error (wobbling in lane) results in a 3% increase in rolling resistance. Just some atarters.
My best run in my '02 WRX wagon was Niagra Falls to Sarnia/Port Huron at 30.3 mpg INTO a 30 to 50 mph headwind, keeping up with traffic so as not to be a hazard. Tires and alignment to spec, slow hands on the wheel, and throtle changes like I had a raw egg between my shoe and the accelerator were probably the biggest contributors.
Good luck, hope nothing is wrong with your car.
Old 10-25-2003, 12:07 AM   #40
Zoso
Member#: 37962
2006 CGM STI
2000 Outback & 05 BMW M3
Default Re: milage
You drive 500 miles a week and got an STi????
Zoso is offline   Reply With Quote
Old 10-25-2003, 02:07 AM   #41
300blueballs
Member#: 39941
2004 Impreza WRX STi
Damn, I get pretty good gas mileage then. I do about 65% city and the rest highway and when I'm on the highway I have a LEAD foot. Accel., slow down, accel....repeat...
I always get about 18-19mpg. The funny thing is I have driven it real easy and still only managed to get barely 20mpg so I figured I'd drive it hard...
300blueballs is offline   Reply With Quote
Old 10-25-2003, 06:17 AM   #42
turbowrx03
Member#: 28866
04 STI
SILVER
Default Re: Re: milage
Yep!
I average about 30K a year driving. I put 21K on my WRX in 8 months.
If you are going to own it...DRIVE IT!
Old 10-25-2003, 07:19 AM   #43
STi-Mulation
Member#: 34722
05 BMX
150 Miles till the yellow light comes on... so 150miles on 42L of 94oct.....
If I have fun then that drops all the way down to 120ish
STi-Mulation is offline   Reply With Quote
Old 10-25-2003, 10:19 AM   #44
catass
Member#: 31976
2004 WRX STi
World Rally Blue
I get 12-14 mpg all city. my commute to work is ~3.5 miles and with plenty of lights, traffic, construction. ugh. (that and I am very impatient and when a slow moving person moves out of my way I almost always end up in boost).
I did notice though I got much better mileage when my commute one week was all highway driving.
catass is offline   Reply With Quote
Old 10-25-2003, 08:44 PM   #45
Maverick1
Member#: 41856
Default Thanks Fogrider....this is my story
-tire pressures are-36 front and 30 rear.
-I average 85mph on the highway and generally step on it in the city.
-I guess I drive it on boost a lot, but so do others on this forum and they seem to get 275-300mpg, while I only get 180-230mpg, and that's city and highway combined.
-DCCD is usually set to auto.
I only have 2700 miles on the car. Will I gradually get better mileage as I put more miles on the car???
Hopefully my mileage will get better soon.
Cheers
Old 10-26-2003, 12:02 AM   #46
Fogrider
Member#: 45806
'04 STI WRB
Default something to try
2 more pounds in the rear for "long hauls" or long commutes might lower rolling resistance a bit but to rule out something that might be a SoA issue, you could try NOT going on-boost for one tank of fuel and see if it made any difference. If you saw the same poor mileage, it would be my conjecture that you have a problem that the dealership should evaluate.
Our ECU's "learn" our driving styles to a certain extent and even modern tight-tolerance engine have a break-in period when moving parts bed in. But if you have some problem of fuel delivery, combustion or utilization of generated power, I doubt that would improve from time alone.
Good luck and let us know what you try/find out.
Old 12-05-2003, 08:11 AM   #47
jv8
Member#: 47455
2004 WRX STi
I miss my vette's 30 mpg highway cruise... my STi is averaging 16.5mpg and I'm not even out of break-in! (50% highway and shifting at 3K or less)
How can they advertise 18/24mpg? Does anybody actually get 18 in the city?
jv8 is offline   Reply With Quote
Old 12-05-2003, 12:19 PM   #48
filbert
Member#: 39661
2004 WRB WRX STi
07 OBP FXTS
on the highway i hit 300 miles, then filled up about 14 gallons, which comes to about 21mpg. but that was with frequent stops and constantly going between 60-80 b/c of break-in. It should do slightly better once i can start using cruise control.
city, i get about 250 (not pushing hard since breaking-in) which is about 17mpg.
Once i'm done with break-in, i'm guessing 200 miles per tank which is about 14mpg.
In order to reach the numbers they advertise, you basically can't enter turbo territory, so if you drive everywhere under 3000rpm then you can probably get that mileage.
Old 12-05-2003, 01:03 PM   #49
StiDreams
Member#: 26315
07 Outback
Silver/Silver
I do at most 20% highway for miles on my STi. About 70% of my miles are surface street commuter miles an average of 45 to 50 mhp. The other 10 % of my miles are my fun miles. They are mostly 2nd through 4th between 4000 and 6000 rpms in twisty hilly terrain. At 5058 miles I'm averaging 18.254 mpg at 11.4 cents per mile. This is data since 2430 miles. I lost a receipt. This is better than I expected. But this just means that I'm not putting in enough fun miles. I guess I'll have to work on getting my mpg down .
StiDreams is offline   Reply With Quote
Old 12-05-2003, 02:15 PM   #50
Negative
Member#: 49847
2004 WRX STi
Java Black Pearl
Originally posted by DISCOPOPE
ive got no clue....
im too lasy to write these things down...
Awesome little tool to track all this stuff:
http://palmfuellog.sourceforge.net/
My stats for the first 4000 miles:
Avg MPG: 16.90
Avg Miles/tank: 206.21
Avg Days b/t fills: 7.1
Max Miles/tank: 272.9
Total Miles: 3918.0
Total Amt Spent: $374.34
Fuel Cost/Mi: $0.09
Negative is offline   Reply With Quote
Improve Your Gas Mileage!! Ekeenan86 Service & Maintenance 75 08-18-2008 03:17 AM
whats your gas mileage and horsepower? ccacher1 General Community 55 07-04-2008 10:30 PM
How's your gas mileage been? Mine stinks. Siper2 Mid Atlantic Impreza Club -- MAIC 65 09-13-2005 03:28 PM
TDO6 20G owners post your gas mileage. STI ONLY fastwrx006 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 03-03-2005 05:35 PM
Whats your gas mileage? wReXeRw Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 01-27-2003 07:33 PM
