Old 10-17-2003, 05:24 PM   #1
sti_rx7
Member#: 38456
Default Omori Gauges
Just received my omori gauges and did a search on using the factory dimmer with the gauges and found no real solutions except for using diodes or a pot switch. Did anyone come up with any other solutions?
Also can I wire the 2 grounds of the omori gauge to a common ground? Can it be the ground wire in the clock harness?
I have 2 gauges so that would be a total of 4 ground wires hooked up to the clock ground wire. Any problem with that? I also plan on using the power and 12V switched off the clock harness as well.
Any feedback is much appreciated
sti_rx7 is offline   Reply With Quote
Old 10-17-2003, 10:19 PM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Default Re: Omori Gauges
[b]Just received my omori gauges and did a search on using the factory dimmer with the gauges and found no real solutions except for using diodes or a pot switch. Did anyone come up with any other solutions?
unfortunately, because of the variable ground system Subaru uses, there really is no other way - you have to convert what the car is putting out into what the gauge wants to see.
You sure can, and the clock harness is fine (that's what most people use - I am using that for my Omori electronic boost gauge with no problems)
Not a problem.
That's the easiest place to grab it if you are putting the gauges on the dash somewhere or on the a-pillar.
Old 10-18-2003, 04:00 PM   #3
sti_rx7
Member#: 38456
Talking done with install
Just finished the install of my Omori boost and EGT. I have the ones with the included color adjustment box and to my surprise you can vary the intensity of the gauge lights. I'm very happy now all I have to do is decide where to tap for my EGT probe, manifold or downpipe.
Thanks
Old 10-18-2003, 09:45 PM   #4
Joe Newbie
Member#: 31085
2003 WRX sedan
My apologies for a momentary thread-jack, but I gotta ask:
sti_rx7
What color are the needles on those Omori multicolors, and where did you get them? Pictures show white with a red tip, but other have told me they are solid red needles, while some have said they are pure white needles.
We now return you to your regularly scheduled thread.....
Joe Newbie is offline   Reply With Quote
WTT: 45mm EGT omori gauge for 52mm Omori oil pressure gauge (NY) gopsu Interior/Dressup/Audio & Security 0 08-29-2009 11:17 PM
Brand new in Box Omori 52mm Omori Gauges and BNIB Defi Pod 02/03 WRX fej Interior/Dressup/Audio & Security 6 11-30-2007 03:52 PM
What gauge to go w/ the 45mm Omori gauge for '04 mouserWRX Electrical & Lighting 2 12-11-2003 01:51 PM
FS: Omori Gauges/Stock Pod modified for 52mm Gauges WRXerist Private 'For Sale' Classifieds 16 09-19-2003 02:55 PM
omori gauge in stock boost gauge housing? savka Interior & Exterior Modification 1 06-28-2002 08:34 AM
