Old 10-17-2003, 07:55 PM   #1
james_gt
Member#: 20852
1995 Impreza L
Red
Default wastegate problems
I already posted in the conversions forum but I figured that u guys have these engines as well.
I just did an engine swap using a 93 legacy 2.2 turbo engine and put it in a 95 impreza. I am having trouble setting up the hoses on the wastegate valve. If anyone could find a picture of theirs or a diagram it would be greatly appreciated.
Also the engine cuts fuel when I press the pedal past a certain point. It doesnt shut the car of but it feels like it stops all fuel to the engine. Any help is greatly appreciated
James
james_gt is offline   Reply With Quote
Old 10-17-2003, 09:59 PM   #2
legacy92ej22t
Member#: 42659
92 Legacy turbo5mt
All go and no show...
Sounds like you're hitting fuel cut. You get fuel cut at 13 psi. Do you have a boost gauge? Are you using a MBC?
There is 3 hoses hooked to the stock boost control solenoid. The bottom one goes to the intake resonator box before the compressor inlet.IIRC the middle one goes to the wastegate valve controller and the top one goes to the nipple on top of the turbo. hope this helps.
legacy92ej22t is offline   Reply With Quote
Old 10-18-2003, 09:25 AM   #3
james_gt
Member#: 20852
1995 Impreza L
Red
that helps a lot thank you.
I also have a question as to where the vacuum nipple on the intake manifold goes. I plugged and the car worked for a while.
James
Old 10-18-2003, 09:48 AM   #4
legacy92ej22t
Member#: 42659
92 Legacy turbo5mt
If you're talking about the one on the front passanger side of the intake manifold it goes to the pressure exchange solenoid. It should have a T in it that goes to the purge solenoid valve #2 also. If you run a boost gauge this is the line you will T into. I'll post a couple pics sometime today to help you out.
Old 10-18-2003, 02:23 PM   #5
james_gt
Member#: 20852
1995 Impreza L
Red
Thank you Pics would help greatly.
James
Old 10-18-2003, 11:26 PM   #6
legacy92ej22t
Member#: 42659
92 Legacy turbo5mt
Sorry, The site I use to upload pics isn't working again and the attach file option on here isn't working out. If I can figure out a way to post the pics I will soon.
Old 10-19-2003, 08:56 AM   #7
simpreza2
Member#: 20381
04 Forester X
93 240sx
If ya want you can e-mail them to me and ill host them on my site.
Jon
simpreza2 is offline   Reply With Quote
Old 10-19-2003, 09:00 AM   #8
james_gt
Member#: 20852
1995 Impreza L
Red
Yes please do
Thanks for all the help
James
Old 10-19-2003, 08:02 PM   #9
james_gt
Member#: 20852
1995 Impreza L
Red
bump
Old 10-19-2003, 09:54 PM   #10
legacy92ej22t
Member#: 42659
92 Legacy turbo5mt
Jon
Thanks, I couldn't e-mail them to you using the e-mail attach. through NASIOC ( couldn't figure out how to add attachments). I sent them to james_gt direct though. Thanks anyways,
-Matt
Wastegate problems james_gt Subaru Conversions 0 10-17-2003 07:53 PM
wastegate problem lotusTT Normally Aspirated with bolt-on Forced Induction Powertrain 5 08-07-2003 09:35 PM
HKS wastegate problem Avenger Normally Aspirated with bolt-on Forced Induction Powertrain 7 11-20-2002 12:44 AM
Need help with HKS wastegate problem rhdude Normally Aspirated with bolt-on Forced Induction Powertrain 5 06-22-2002 12:34 PM
Wastegate problems awd1320 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-02-2002 08:45 AM
