Old 10-17-2003, 10:05 PM   #1
SubaruWRC
Member#: 11063
2001 Impreza 2.5 RS
and bye bye Turtle :(
Default Headlight grounds on a GC8
Can anyone tell me where they are, i got a headlight that is dim, and someone told me to check the ground to it.
thanks
Jiffy
SubaruWRC is offline   Reply With Quote
Old 10-17-2003, 10:35 PM   #2
I Wish
Member#: 19278
http://www.piranhaoffroad.com.au/com...tail.htm?id=11
I have purchased one and it really does make a difference, even with the standard bulbs.
Very straightforward installation and you can really see how small the oem wiring is.
I Wish is offline   Reply With Quote
Old 10-18-2003, 01:02 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
First of all the Subaru headlight system is a common positive, switched ground system. There are no direct "grounds", the low and high beam are switched to ground through the headlight switch to turn them on.
If one of your lights is dim the most likely cause is a blown headlight fuse on that side. A blown fuse will cause the bulb to pull power through the filaments from the other side and light up dimly.
Old 01-04-2004, 09:48 PM   #4
SubaruWRC
Member#: 11063
2001 Impreza 2.5 RS
well the fuse wasent blown, i swiched them around, so i dunno what to do,
anyone else got any suggestions
Jiffy
EDM headlight grounds omdwrx508 Electrical & Lighting 3 04-08-2007 02:40 PM
Cleared MY05 headlights + grounding mod---PICS jmanny152 Interior & Exterior Modification 8 03-06-2005 04:37 AM
FS:Rotors, morrete headlights, grounding kit, car alarm, carbon vents, Grp N top hats Axan Private 'For Sale' Classifieds 24 11-07-2004 01:52 PM
Morette Headlight Conversion for my GC8 ZzSleEpEr13zZ Interior & Exterior Modification 2 12-23-2002 02:23 AM
GC8 headlight ground mod question willguidry General Community 7 12-14-2002 11:45 PM
