Old 10-18-2003, 01:55 PM   #1
WReX N Effect
Member#: 37590
Default probably the DUMBEST question ever posed...
OK, I realize by asking this question, I run the risk of being severley ridiculed, but I'm going to ask anyway...
I am in the process of installing my turbo timer (Apexi)...
when I shut the ignition off, and the car keeps running, it can't be "in gear" right? The reason I ask is I'm not sure if there is some sort of clutch bypass wire or something in the mess of wires that plugged into the HKS harness.
I assume the sequence is
1) pull the parking brake
2) leave trans/gearshift in 'neutral' (5spd manual)
3) turn ignition to 'off'
4) remove key
5) close door and hit lock on remote
6) walk away with car still running and hope it doesn't roll down my driveway onto the street
I know I'm an idiot so it is not necessary to post a response stating the obvious...just laugh to yourself and tell me if the sequence is correct.
thanks
WReX N Effect is offline   Reply With Quote
Old 10-18-2003, 02:38 PM   #2
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
yep that's how you do it. If you left it in gear and took your foot off the clutch, the car would jump forward and stall.
lotusTT is offline   Reply With Quote
Old 10-18-2003, 07:53 PM   #3
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
Default Re: probably the DUMBEST question ever posed...
Yup, that's why I'll never install a turbo timer an a car with a manual transmission.
vrg3 is offline   Reply With Quote
Old 10-18-2003, 10:02 PM   #4
Estiem
Member#: 15469
05 FoReStAAr Xt
Salty Road Grime Grey
the only time TT's are a major problem is if you let someone who doesn't know what's going on, drive it.
most of the time the dealer won't even use the ebrake anyways, they just turn the car off in gear, hence bypassing the TT altogether.
Estiem is offline   Reply With Quote
Old 10-18-2003, 10:41 PM   #5
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Default Re: Re: probably the DUMBEST question ever posed...
So why would the parking brake work less well with the engine on and the transmission in idle? Parking brake failure isn't going to be impacted by the engine idling with the transmission in neutral...
Old 10-18-2003, 10:47 PM   #6
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
Normally, when you park a car with a manual transmission, you leave the parking brake on and leave the transmission in gear. That way you have a backup in case the parking brake fails (if you're in gear then the engine's compression acts as a brake).
Old 10-19-2003, 09:23 AM   #7
speedblind
Member#: 42202
Of course, there's always the option of turning the TT off completely. I always turn it off if I bring it in for service/park on a hill.
speedblind is offline   Reply With Quote
Old 10-19-2003, 03:34 PM   #8
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
Yeah, there's always that option.
Hey, it'd be neat to make a turbo timer that could detect when you were parking on an incline and warn you not to leave it running out of gear or something. 'Course it wouldn't help the case of your car being bumped by another car or anything, but still...
Old 10-19-2003, 06:57 PM   #9
FryRice
Member#: 38402
2004 WRX~vf34 SOLD
EVO MR
Have the e-brake actually fail, that happen to you people??? because i do the same as he does...........
FryRice is offline   Reply With Quote
Old 10-19-2003, 07:21 PM   #10
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
Guys this really isn't that hard. If you're parked on an incline or some place where you're worried about just using the parking brake...turn the turbo timer off! Or sit in the car with your foot on the brake til the turbo timer turns off then put it in gear. All it takes is a tiny bit of common sense and you will have absolutely no problems.
Old 10-19-2003, 08:09 PM   #11
j.reed
Member#: 34582
2005 Legacy GT LTD
Obsidian Black
I was just going to say that... if you are in a flat parking lot, leave it. If you're on a hill, sit in the car with it! Whats your wait? 2-3 minutes? Leave early!
j.reed is offline   Reply With Quote
Old 10-19-2003, 10:55 PM   #12
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
Also, if you anticipate parking on a slope you can just avoid working the turbo in the minute or two before you park. A lot of the time you're driving through a neighborhood or parking lot anyway.
Old 11-15-2003, 02:02 AM   #13
zeroFX
Member#: 10636
2002 Impreza WRX
World Rally Blue Sedan
How about if the car is a 4eat ? Do you still have to leave it in neutral ?
zeroFX is offline   Reply With Quote
Old 11-15-2003, 02:09 AM   #14
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
No, you can leave a 4EAT in park with the emergency brake on.
Old 11-16-2003, 12:18 PM   #15
Extraze
Member#: 16980
or you can always turn your wheels towards the curb... so if your car's e-brake decides to stop working, your car will simply roll down a feet or two until it hits the curb ... alot of people tend to forget about this little trick...
Extraze is offline   Reply With Quote
Old 11-18-2003, 12:04 PM   #16
Speedwagon
Member#: 19681
1998 Legacy Wagon GT
Green
Small engined cars will roll down a hill with it in gear anyways. I know, cuz I've had it happen. The parking brake cable broke, so I had to park with it just in gear. The car just started jerking backwards down the hill. I promptly moved the car to more level ground...
But it was a real small engine.. a 1981 Toyota Corolla/Tercel.
Speedwagon is offline   Reply With Quote
Old 11-19-2003, 04:48 AM   #17
WReX'n'Effect
Member#: 22368
2011 WRX Limited
Obsidian Black Pearl
4) remove key
thanks
Wow I saw this and thought someone was punkin me!! change yer name dude, especially if you are going to be asking "the dumbest question ever posted..." haha I had it first. I mean, you even wrote it the exact same, come on....
WReX'n'Effect is offline   Reply With Quote
Old 11-19-2003, 03:38 PM   #18
SubaruPartsGirl
Member#: 37513
SubaruPartsGirl is offline   Reply With Quote
Please help me with the dumbest question ever sonicsuby Bay Area Impreza Club Forum -- BAIC 7 05-30-2003 01:35 PM
the dumbest question ever...rev limit? M3toWRXin3seconds Newbies & FAQs 16 02-03-2003 12:16 PM
quite possibly the dumbest question ever asked in this forum juztin180 Newbies & FAQs 10 02-26-2002 06:09 PM
The Dumbest question ever SillyAssKilby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-05-2001 10:10 AM
