Old 10-19-2003, 12:51 AM   #1
sonic rx
Member#: 33457
Chapter/Region: PRSIC
HAHA EVERYONE KNOWS
DYNO JET IS NOT REAL WHP
Default greddy egt probe fitting???
i bought a greddy egt 60mm with warning and memory.for some reason the probe fitting(the part that would thread into the manifold) was missing .the manual shows a picture it looks like a regular compression fitting.so my question is .is it a normal compression fitting like the kind you would by for puttig 2 peices of hard line together(trans lines,brake lines ,or water lines for the ice cube maker for the fridge) if it is is it 1/8" for the probe or does anyone know the correct size? car is apart so quick help would be awsome thanks
sonic rx is offline   Reply With Quote
Old 10-19-2003, 10:15 AM   #2
jawbreaker
Member#: 15481
2010 Evolution X GSR
Grey and Dirt
I'm pretty sure the fitting is 1/8" BSPT...British Standard Pitch Tapered, or something like that.
Good luck.
jawbreaker is offline   Reply With Quote
will a defi egt probe fit into the factory uppipe egt location? blackie Factory 2.0L Turbo Powertrain 1 09-08-2003 12:32 PM
Greddy EGT probe install MAD REX Factory 2.0L Turbo Powertrain 14 04-03-2003 01:05 AM
Defi and Greddy EGT probes. Interchageable? Dougeefresh Factory 2.0L Turbo Powertrain 4 11-06-2002 04:07 PM
Is the Greddy EGT probe easy to break? pico Factory 2.0L Turbo Powertrain 7 04-23-2002 07:33 PM
HELP: greddy EGT probe viodea Factory 2.0L Turbo Powertrain 15 12-04-2001 03:58 PM
Message Board Statistics All times are GMT -4. The time now is 06:46 AM.
