Old 10-19-2003, 12:16 PM   #1
Ken 02
Member#: 12216
2002 Impreza WRX
Default need oil pressure gauge install help
hey guys,
I'm about to install my Autometer Mechanical oil pressure gauge and i'm not sure which oil line to tap into to get my oil pressure reading. Any help would be appreciated!
Thanks.
Ken 02 is offline   Reply With Quote
Old 10-19-2003, 12:59 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Is this a fully mechanical gauge, with tubing that goes from the engine all the way to the gauge itself? If so you should exchange it for an electrical one. There is no good reason to install a mechanical gauge when electrical ones are just as accurate, and far safer because they don't require running a line with hot, pressurized oil into the passenger compartment.
Old 10-19-2003, 04:55 PM   #3
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
Hey Ken,
I wouldn't worry about having oil leak into the cabin. Yes its possible, but if you are careful and hook everything up properly you won't have any problems. Make sure you use teflon tape on all the fitings. To tape for oil, underneath your intercooler there is a galley plug with an allen wrench hole in it. Go to your local dealer and buy the galley plug that is used in the stock oil pressure sender. You have the proper fitting to fit into the galley plug with the guage. I'd give you a link to the scoobymods directions but their server's down now.
lotusTT is offline   Reply With Quote
Old 10-21-2003, 03:01 AM   #4
DubareX
Member#: 27924
2003 WRX
Default found somthing
DubareX is offline   Reply With Quote
Old 10-21-2003, 08:37 PM   #5
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
As long as you use copper line or stainless steel braided line, it shouldn't leak for years. Even nylon tubes would be enough, but they're easier to cut/break. Whatever you do, do not overtighten the end-fittings at the gauge and the sender.
tmat3 is offline   Reply With Quote
Need answer ASAP prosport oil pressure gauge install Jkmaynard Newbies & FAQs 17 10-21-2010 07:15 AM
Oil Pressure Gauge Install Help Blurvision Normally Aspirated Powertrain 4 06-03-2004 10:40 PM
Need help - oil pressure gauge install Faulk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-11-2004 02:30 PM
Completed Greddy oil pressure gauge install! Force[FED] Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 09-28-2001 10:14 AM
('93-'01) HEELPPP!!! Oil Pressure gauge install.... T-WReX 2.5RS Impreza Forum 2 05-07-2001 05:06 PM
