Old 10-19-2003, 09:36 PM   #1
cbose
Member#: 45553
1991 Legacy VZ
Green
Default power steering pump rebuild
The Car: 91 Legacy VZ (2.0 litre)
195,000 KM
The Problem: Noisy PS pump. Pump emits a soft whine at all speeds. Prepurchase inspection mechanic tagged it as 'noisy -- look into it' The pump looks pretty easy to refurbish. Assuming I have a kit, is it possible to rebuild the pump at the bench without special tools?
Possibly Related Problem: The steering rack is leaking badly from the boots and from the input shaft seal. Used, low mileage rack is easy to locate at a nearby wrecker, but it won't help much if the PS pump is blowing out the seals -- thought it best to start at the top and make sure the bypass valve is working right.
And no, I don't have access to PS pressure test gear -- would have to hire someone to do it.
Chris
cbose is offline   Reply With Quote
Old 10-21-2003, 04:34 AM   #2
jlevy
Member#: 15696
2015 WRX 6 speed
PLAYER posted something on rebuiling the pump a while back (http://forums.nasioc.com/forums/show...hreadid=222470). There is really no reference to the part numbers you'll need, but he doesn't make it sound that hard.
-JL
jlevy is offline   Reply With Quote
Power steering noise but maybe not the power steering pump.....? deathskrye Brakes, Steering & Suspension 5 08-29-2008 10:56 PM
Converting power steering pump to crankcase vacuum pump? bugeyes Built Motor Discussion 8 04-12-2008 11:38 PM
Power steering pump pumping air? Ozzman Service & Maintenance 1 03-18-2007 11:50 PM
Power steering pump, STi V4. Any other pumps fit? STi_v4_Wagon Subaru Conversions 4 01-01-2007 01:41 PM
Power steering pump, STi V4. Any other pumps fit? STi_v4_Wagon Brakes, Steering & Suspension 0 12-30-2006 11:19 PM
