Old 10-19-2003, 09:40 PM   #1
aross
Member#: 831
11 Blurple WRX
03 BH MBP
Default Oil Light on at idle
So,
I am looking at this 91 Turbo Legacy.
Oil light is on at idle, car runs fine otherwise, a little clicky. And needs a few other cosmetic, and brake type stuff.
So, do I order that block from the local wrecker, or pull it apart and replace all that is toast.
car has 250K Kms
Car runs fine above 1500Rpms
aross is offline   Reply With Quote
Old 10-19-2003, 10:28 PM   #2
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
This is a silly question, but did you check the oil level?
A little more info will be needed...
-Brian
KD7000 is offline   Reply With Quote
Old 10-20-2003, 07:13 AM   #3
aross
Member#: 831
11 Blurple WRX
03 BH MBP
Oil level is fine, I plan on changing it and the filter to make sure the filter is not plugged etc.
Old 10-20-2003, 07:53 AM   #4
subarurabbit
Member#: 4083
2011 OB 3.6R
I'd get the oil pump resealed or replaced...
subarurabbit is offline   Reply With Quote
Old 10-20-2003, 09:08 AM   #5
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
probably the o-ring on the oil pump, that and/or the screws holding the backing plate on have backed out.
Either way you'll need to get at it. to fix it.
Legacy777 is offline   Reply With Quote
oil light on while idling whitehorse06 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 04-21-2010 08:12 AM
Oil light flickering on at idle after warmup greenobs97 Normally Aspirated Powertrain 7 01-10-2010 01:18 PM
oil light on at start up? 04works Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 32 01-09-2010 11:40 AM
Oil light on when idling Pow_Pow_BCC Service & Maintenance 11 04-29-2009 12:28 PM
Oil Light Comes On At Idle TheHeroOfYou Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 20 07-21-2007 02:36 PM
