Old 10-20-2003, 03:45 AM   #1
mbwrx20
Member#: 31432
2002 wrx
midnight black
Default rear wheel stud change.
How do you change the wheel stud in the rear??? I stripped one and I need to change it out??. Do you have to take the whole hub out?? If so, HOw??????
mbwrx20 is offline   Reply With Quote
Old 10-20-2003, 10:21 AM   #2
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
From what I saw with a friend's 2.5 RS, you just remove the wheel, caliper and rotor. The hub should be right there with a few (5 or so) screws holding a plate that holds the studs on. It should be about the same for a WRX.
If this is wrong, someone please correct me.
IronMonkeyL255 is offline   Reply With Quote
Old 10-20-2003, 12:14 PM   #3
X1_SRT
Member#: 31323
02 RS
midnight
the studs are actually pressed into the hub. line up the stud with the hole in the back, look you'll see it, and knock the stud out. an air hammer works the best.
for installation, we used to put the stud in as far as it would go, use the end of an old closed end wrench for a spacer, and an old lug nut. then use an impact gun (although this is probably not as good an idea as say a torque wrench) to pull the stud tight to the hub.
-PJ
X1_SRT is offline   Reply With Quote
Old 10-20-2003, 01:51 PM   #4
mbwrx20
Member#: 31432
2002 wrx
midnight black
The thing is I have bought arp longer studs. they are 2.5 inches long. so I guess I am gonna have to take the hub out.
Old 10-20-2003, 02:59 PM   #5
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
I was close. Just didn't realize they were pressed in.
A rear wheel stud change? Kahn23 Brakes, Steering & Suspension 9 08-28-2010 02:52 PM
change rear wheel studs with drum brakes? jasona Brakes, Steering & Suspension 1 05-26-2006 12:58 PM
Replacing rear wheel studs, difficulty? Chav Tire & Wheel 8 09-28-2005 11:43 PM
rear wheel stud replacement??? mbwrx20 Brakes, Steering & Suspension 2 10-20-2003 02:11 PM
stripped rear wheel stud problems eastbaysubaru Service & Maintenance 7 08-16-2002 01:52 PM
