Old 10-20-2003, 09:43 AM   #1
Charlton
Member#: 43038
2002 Forester S
Default Vacuum/boost gauge
I am new to this forum and I was wondering if you can use an Autometer vacuum/boost gauge to read the vacuum pressure in my engine while driving. I have a NA 98 Legacy GT sedan. I was looking in my Haynes manual and they describe a vacuum test as being a cheap and easy way to check the functioning of the valves and other engine components. I know that the phase 1 block that I have is prone to headgasket failures and a vacuum test can reveal a leaky headgasket if it is read right. I have an Autometer air/fuel ratio gauge in my GT right now but honestly it is useless unless I can adjust the ratio with an s-afc(which I don't care to have). Will this vacuum/boost gauge be a good gauge to have or is there a better gauge to use to monitor engine vitals? I was thinking water temp gauge but my GT already has a stock op.temp gauge. Any suggestions?
Charlton is offline   Reply With Quote
Old 10-20-2003, 02:11 PM   #2
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
A Vaccum/Boost gauge will be a nice thing to have and may give you a little bit of indication if your Head Gaskets are failing. A compression tester would be a much better investment if your looking at monitoring your head gaskets.
MY99 2.5GT is offline   Reply With Quote
Old 10-20-2003, 02:11 PM   #3
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
Oh Yeah. Why do you care to not have an SAFC?
Old 10-20-2003, 03:52 PM   #4
legacy92ej22t
Member#: 42659
92 Legacy turbo5mt
All go and no show...
Unless you have FI you don't need a vac/boost gauge. You should just run a vacuum gauge. It's probably cheaper too.
legacy92ej22t is offline   Reply With Quote
Old 10-20-2003, 11:12 PM   #5
Charlton
Member#: 43038
2002 Forester S
Thank's for the response and I am going to go with a regular Autometer vacuum gauge. Can someone tell me if any of the dual guage pods that fit on the window pillar fit our 98 Legacy GTs?
Old 10-21-2003, 08:39 AM   #6
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
I was told the Impreza Dual pillar pod will fit our cars.
20590
Autometer Dual Pillar Pod
http://store.summitracing.com/partde...rt=ATM%2D20590
$27.95 - Summit Racing
Brad
Autometer vacuum/boost gauge Chi_San Newbies & FAQs 9 05-13-2009 01:29 PM
wtt: lamco boost gauge for vacuum gauge bue car Private 'Wanted' Classifieds 25 02-16-2009 05:22 PM
Vacuum/Boost Gauge Install dkane Electrical & Lighting 7 05-30-2008 11:04 AM
boost gauge boost/vacuum source Rayme Newbies & FAQs 7 03-10-2008 03:44 PM
Autometer Z-Series, Boost/Vacuum, 30 in. Hg/20 psi., 2 1/16 Mechanical Boost Gauge lstepnio Private 'For Sale' Classifieds 2 12-12-2004 11:11 AM
