Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 10-20-2003, 07:34 PM   #1
pleiades
Member#: 2491
06 Miata
81 Fiat Spider
Default Tire Fitament problems on GT (please post if you know)
I've got a few questions. I was just installing new brake pads and putting a set of Rota Sub-zero's on. They have 225/45/17 S-03's (mostly worn out). Any word about if this works or not? It's pretty darn close in there. lol.... I'm running Tein HA's with thier stock rates. Height is probably approx. 1.75" drop from stock. I'm gonig to finish the brakes on the other side of the car. Thanks for any info!
Steven
pleiades is offline   Reply With Quote
Old 10-20-2003, 08:03 PM   #2
etam
Member#: 439
www
225 45 17 + 1.75 drop = >95% rub
be prepare to roll the fender!
etam is offline   Reply With Quote
Old 10-20-2003, 08:28 PM   #3
monovich
Member#: 8124
1998 Old Grey Mule
Regacy Rype R
or you could do what I did and think happy thoughts while the tires and wheels are getting installed. works every time, no rubbing.
monovich is offline   Reply With Quote
Old 10-20-2003, 09:37 PM   #4
richeich
Member#: 1353
2001 Impreza 2.5RS
Damn, I wish I would've known that! I had to roll mine.
Yep... 225's = rolled rear fenders.
Rich
richeich is offline   Reply With Quote
Old 10-20-2003, 09:57 PM   #5
etam
Member#: 439
www
hmm.. I wonder if offset +48 or +55 make a difference?!?!?
Old 10-20-2003, 10:05 PM   #6
richeich
Member#: 1353
2001 Impreza 2.5RS
I've got SSR Competition wheels, 17 x 7.5, 50mm offset. Tires are Falken Azenis 225,45-17. STi V5 struts with H&R Sport springs, approximately 1.2 in drop.
Clearance is very close on the struts, and must occasionally rub, since there's some black scuffs showing (no evidence of it on the tires, though). Rear fenders had to be rolled. I couldn't even get out of the parking lot without zingin' the rears on the fenders. That's all the wheel and tire I can stuff in there.
Old 10-20-2003, 10:33 PM   #7
pleiades
Member#: 2491
06 Miata
81 Fiat Spider
Thanks for all the info guys. I went ahead and put them on. I also raised the car back up to within 1/2" of stock height, so hopefully it'll be ok until I can get some rolling done. Did you guys use a real roller or a bat?
Old 10-20-2003, 10:44 PM   #8
anotherB4
Member#: 6120
BE5B AVOed B4-RSK
Sorta White
Admittedly Paul Hansen has a BE, but he is only a touch lower than std and gets contact in the rear with 225/45-17 on ET53 JDM std STi wheels.
And the earlier cars were ven tighter in the rear wheel wells IIRC...
anotherB4 is offline   Reply With Quote
Old 10-20-2003, 11:54 PM   #9
monovich
Member#: 8124
1998 Old Grey Mule
Regacy Rype R
they may be tighter, but I'm rolling around with 18x7 225/40/18 +55 with about 200lbs of weight in the trunk (old wheels and tires + junk). I'm also lowererd. I'm still not rubbing.
-s
Old 10-21-2003, 01:01 AM   #10
MannySoobia
Member#: 22139
2008 FXT Sport
Gee-Are-Pee
Question
O.K. So I'm gonna ask, probably what will be the Noob question of the year.
-- What exactly is, "Rolling the fenders"?? How much does it run?? And does anyone know where I could get it done?? In So.Cal that is.
I'd like to Pre-thank anyone that can give me an answer to any of the forementioned questions.............THANX
-- Manny S.
MannySoobia is offline   Reply With Quote
Old 10-21-2003, 01:19 AM   #11
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
About 45 posts down
Pretty good visual representation.
You're basically taking the horizontal lip on the edge of the wheelwell and folding it up so it fits closer to the vertical profile of the fender/quarterpanel itself.
That lip is usually what rubs, especially on Subarus, and all you usually need, unless you have constant tire/fender contact, is that little bit (usually 1/2 inch or less) of extra clearance, especially if you're lowered and/or carrying weight.
That said, I run 225/50/16's on RS 16x7's (53 offset) and even with ~1200 pounds of cargo and the rear tires entirely inside the fender at rest, and the wheel disappearing over bumps, I didn't rub.
Most motorsports and decent tunig shops will be able to point you in the right direction of a shop with a roller (the best, and safest way to do it). Or you can go ghetto and just do it with a wooden baseball bat
sybir is offline   Reply With Quote
Strange electrical problem - Please help if you can Rice & Gravy Car Audio, Video & Security 12 04-01-2006 12:48 AM
2006 Subaru Impreza Ad on TV?? Please post the ad on the internet....If you have it neuspeed News & Rumors 6 07-26-2004 09:57 AM
Can U bring the govt. to small claims court? (serious. please read if you know) LONG! Eric SS Off-Topic 41 06-14-2004 10:43 AM
Please post if you have a WRX wagon scoobyruman New England Impreza Club Forum -- NESIC 11 07-23-2001 12:37 AM
Any last minute advice???? Kinda long..Please Help if you can Scooby South Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-19-2001 01:27 PM
