Welcome to the North American Subaru Impreza Owners Club Thursday June 20, 2013
Old 06-20-2000, 11:33 AM   #1
Skeandhu
Member#: 1056
Have a Nice Day? air conditioning lag?
Just wondering if anyone else notices this as well...
When driving with A/C on, there is a noticable reduction in the performance. This is to be expected, and is not a problem. However, I find that the reduction in performance is not constant. ie: when driving with the A/C on, and consistant pressure on the accelerator (to maintain constant speed) the car seems to lurch a bit, almost as if I was flicking the A/C on and off.
Some notes on the car: MY00 RS, approx 9000km (less than 6000 miles) on odo.
Is this a common thing or should I be checking with the dealer??
Input greatly appreciated.
Skeandhu is offline
Old 06-20-2000, 11:54 AM   #2
ttoversteer
Member#: 465
2012 GTI
Gray
Post
I wouldn't worry. I have a MY99 that does the same thing. The lurching you feel is when the compressor turns itself on and off as it tries to maintain a constant temp.
ttoversteer is offline
Old 06-20-2000, 05:28 PM   #3
Warp3
Member#: 161
06 WRX TR (SGM)
89 MR2 (Ice Blue)
Post
I've noticed on my 99 2.5RS that it feels like the A/C partially disengages at 3k then moreso at 4k. I'm not sure how it "partially disengages" but I know there is a jump in power at both RPM points even under light throttle (and this doesn't seem to happen with the A/C off at either RPM point). Also I'm pretty sure the A/C disengages at full throttle regardless of RPM (I'm pretty sure all modern cars do that).
Warp3 is offline
Old 06-21-2000, 12:00 AM   #4
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Post
Actually, the AC compressor is designed to shut off under heavy (what SOA calls "emergency acceleration", what we prefer to call "spirited driving"). Just check your users manual, it's in there. I believe it's been on every AC'd subaru since about 88 or 90.
North Ursalia is offline
Old 06-21-2000, 12:24 AM   #5
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
I specifically noted that the AC compressor didn't affect RS much when shopping a year and a half ago. Compare to the Civic Si, for instance. (yes it's displacement.)
I'm perfectly happy with the part and WOT performance of my RS running the AC. Well, not perfectly... The car needs another 100HP or so, but it performs nearly normal with the AC on.
ColinL is offline
Old 06-21-2000, 12:36 AM   #6
mpaone
Member#: 3
2012 Geeteeeye
and 71' VW Gulf Beetle
Question
On a similar subject, do any of you hear a slight "squeak" when the air turns on or off? This has been happening in my 99' lately. I have an underdrive pulley... could it be that the belt needs tightening? I especially hear it when letting off the gas after full throttle (with the air on).
mpaone is offline
Old 06-21-2000, 12:51 AM   #7
Matt
Allergic to turbos
Member#: 181
Two Subarus and
a truck
Post
You'll probably need to check the belts. And yes, the A/C usually turns off around 4500rpm when accelerating hard, then re-engages at 4000rpm. Of course this is on my 1.8L so it may be different on the 2.5L.
Matt is offline
HTML code is On
Fresh (hot) air versus air conditioning? foreSTir Texas Impreza Club Forum -- TXIC 37 08-06-2004 06:38 PM
Need help with Air Conditioning bvass Normally Aspirated Powertrain 1 06-11-2001 04:14 PM
Help! 98 to 99 Air conditioning question Rally-RS Normally Aspirated Powertrain 2 06-07-2001 10:22 AM
('93-'01) Air conditioning question... Rally-RS Impreza Forum 0 06-03-2001 12:34 AM
Message Board Statistics All times are GMT -4. The time now is 04:48 AM.
