Old 10-21-2003, 12:16 PM   #1
grknss
Member#: 44592
2004 WRX STI
Platinum Silver Metallic
Question OEM Boost gauge question
Anyone know how to get to the bulb on the OEM single boost gauge on the column for the STI?
The rubberized cover needs to come off and from some diagrams I have seen it is hard to see if the bulb comes out from the rear, any ideas or hints would be great,
Thanks
grknss is offline   Reply With Quote
Old 10-24-2003, 11:47 AM   #2
ludecrous
Member#: 19376
2003 03 WRX Wagon
I think it's the same guage as the one on the non STi, here goes.
Bulb is in the back, on the circuit board on the back of the gauge, you have to first remove the gauge from the rubber housing, get small flatblade screwdriver, wrap end in electrical tape to stop from stratching, get some lube spray like Tri Flow or WD40... yes you need this or it will be a bi*tch. Use the screwdriver to pry and add lube (makes it much easier)
Bulb is on back, on mine it's a small black rectangle that you twist to pull the bulb from the circuit board.
Hope this helps.
ludecrous is offline   Reply With Quote
Old 10-24-2003, 12:21 PM   #3
grknss
Member#: 44592
2004 WRX STI
Default Thanks
That's what I had figured, I am going to tackle that tonight or tomorrow, I'll let you know and post some pics if you'd like
Thanks
OEM Boost Gauge Question fkarkvan Electrical & Lighting 0 08-15-2009 01:38 PM
FS: OEM boost gauge AND dynotune digital boost gauge AaronWRX Mid Atlantic Impreza Club -- MAIC 3 07-14-2005 11:22 PM
Question On OEM Boost Gauge Bumsarama Electrical & Lighting 10 08-10-2004 02:14 AM
OEM boost gauge install - question WRXVII Service & Maintenance 6 12-08-2002 03:51 PM
Question about OEM boost gauge CWasko36 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-19-2002 09:55 AM
