Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 10-21-2003, 08:10 PM   #1
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
Default Headlights Condensation?
So did the headlight mod to remove the amber reflector from the headlights on my 2000 legacy gt limited sedan. After a FEW weeks, the front right headlight started to build up a lot of condensation inside of it. So i cooked it again, this time i put a ton of caulk in there to insure a proper seal. the next few days it was pretty cold out again, still not condensation. Here comes today when its about 65 this afternoon, and a VERY small bit on condensation has built up in this same headlight. Is this normal for any type of headlight to occur occasionally? I sealed it VERY well....
Acejam2k is offline   Reply With Quote
Old 10-21-2003, 09:55 PM   #2
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
any1?
Old 10-21-2003, 10:47 PM   #3
pityr
Member#: 31719
you may not have gotten all the moisture out of it when you re-assembled it
Take it off and dry it out. Try taking the bulbs out and use a hair dryer to cycle hot and cool air through it.
pityr is offline   Reply With Quote
Old 10-22-2003, 08:11 PM   #4
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
Its weird though, after a few hours it went away, this morning it was back again, but a very little spot..
Old 10-27-2003, 01:45 PM   #5
ttboy19
Member#: 38043
2004 impreza rs4sale
'10 Legacy 2.5GT
Default Same Problem
I just recently experienced this problem, except that I didn't take my headlamps apart. Only thing different is the new HID's. How do I get rid of the condensation? Heat gun? Hairdryer?
ttboy19 is offline   Reply With Quote
Old 11-21-2003, 03:34 PM   #6
tubbytreats
Member#: 35104
02 WRX TD0518G 7cm
www.daytonsubies.com
Read my DIY on how to do this "Koji headlight mod", and I explain how my lights ended up doing the same thing. The bulbs were wet when I inserted them, and when they turned on it vaporized the water droplets on them into steam which clouded my headlights.
http://www.wrxfanatics.com/index.php...T&f=53&t=1687&
tubbytreats is offline   Reply With Quote
Headlight condensation OBPNUT Interior & Exterior Modification 3 02-01-2008 01:47 AM
2006 Headlight Condensation Ukezu Interior & Exterior Modification 17 01-10-2007 11:56 PM
headlight condensation turbowrx2004 Warranty Issues & SOA Problems 1 12-22-2004 02:57 PM
headlight condensation turbowrx2004 Electrical & Lighting 5 12-22-2004 10:28 AM
DIY Headlight condensation? pDXZ Interior & Exterior Modification 2 12-18-2001 07:32 PM
